IS F front rotors
Old 07-10-13, 09:13 AM
  #196
drifterx27
drifterx27's Avatar
Lots of info in this thread! I am curious of my options since I will be going with CCW Classics 18" and have Supra TT fronts already. Kinda nervous to try anything larger, unless there is a proven solution. Thanks LRD for helping out the forum!
Old 07-30-13, 11:45 AM
  #197
mk4lex
mk4lex's Avatar
I want some caliper brackets please .... if anybody selling them please message me
Old 11-15-13, 09:31 AM
  #198
Murco
Murco's Avatar
Originally Posted by Klaus
Alright so I came across an interesting issue with these calipers in that if you ever have to rebuild them you're going to run into some problems.
There was a local guy selling some z06 PBR 6 piston front calipers however he took them apart to strip them to get them ready for powdercoating. A couple of the seals got damaged in the process which is fairly normal so he was expecting to go to the dealer and pick up a set of new seals which you've always been able to do for GM calipers, even the CTS-V BBK.
No dice. Not only were they $145 PER SIDE (yes, just for the seals) but he said they were "unorderable".
Just to update this, the rebuild kits are now readily available from several sources and a great upgrade is the Stainless Steel Pistons sold by DRM. They insulate the brake fluid much better than the OEM aluminum pistons.
Has anyone worked out a way to use the Z06 Rear Calipers with the IS-F rear rotors? Those red calipers would look really good with my new red car! lol
Old 11-15-13, 02:00 PM
  #199
//LRD
//LRD's Avatar
There is an SC with 18 inch wheels that run this setup. From what I understand they had to shave the fins down just a bit, on the very top of the caliper. Someone started a thread about this car on here.
I tried a few times and didn't like how the brackets came out. A member of CL even went as far as sending me a rear ISF rotor. The good news is the rotor fits like a glove. Bad news was couldn't float the caliper in a way that would be safe. I had the stock one piston rear for the longest. I finally installed the TT rears. One day I'll try again.
Originally Posted by 92blacktt
you just need the adapters, pm me if you need a set
You design some as well ?
Old 11-21-13, 12:13 PM
  #200
//LRD
//LRD's Avatar
I thought this was interesting information. A buddy of mine has mounted SC300 spindles to a MK3. I've heard of people doing all kinds mods to fit big brakes for the MK3's. Not sure if you all knew about this simple mod or not . Should be cool to see the car done with these vette brakes.
Old 02-24-14, 10:05 AM
  #201
//LRD
//LRD's Avatar
Any pictures? from the members whom have done this conversion.
Old 02-24-14, 10:13 AM
  #202
SCereal
SCereal's Avatar
Here's a teaser shot from my install yesterday. Nevermind the filthy wheel and dirty car. For reference, that's a 19" SP500. clears calipers by miles.
Old 02-24-14, 10:58 AM
  #203
92blacktt
92blacktt's Avatar
did u you IS-F calipers as well?
Old 02-24-14, 11:12 AM
  #204
SCereal
SCereal's Avatar
Nope those are the Z06 calipers on the brackets you did. I just painted them to match and stuck a lexus decal on them.
Old 02-24-14, 11:36 AM
  #205
Biddles
Biddles's Avatar
Your brakes look perfect man, nice job. I want I want.
Old 02-24-14, 11:42 AM
  #206
//LRD
//LRD's Avatar
They definitely look awesome in that blue. Nicely done
Old 02-24-14, 12:12 PM
  #207
Tabaka
Tabaka's Avatar
Question, what brake master cylinder are you using? Maybe you mentioned this in the past 14 pages but I'm lazy.
Old 02-24-14, 01:09 PM
  #208
//LRD
//LRD's Avatar
The original. All that is needed is SS brake lines. Even the original banjo bolt from our caliper is reused with Z06 caliper.
Old 02-24-14, 01:21 PM
  #209
SCereal
SCereal's Avatar
Much obliged. I'll be updating my build thread soon with a few more pics and some narratives of my adventure in braking.
Old 03-18-14, 08:05 AM
  #210
97-SC300
97-SC300's Avatar
where can I get these adaptors?
Quick Reply: IS F front rotors
