bleed brakes
i told my dealer to do it when i got my free 5k oil change at the beginning of this year.
will do so again next spring.
haven't done it myself tho. i don't have the proper equipment
Proper equipment? all u need is a hose that fits over the bleeder nipple, a flare wrench or even normal wrench(just be extra careful) and another person. Easy stuff! Just make sure you bleed from the furthest wheel away from the master cylinder first..which is our right rear I believe..I can't remember.
Tech Info Resource
Get Earl's solobleeders and do it yourself. That's what I did.
EAR-280025ERL x 2 for rear
EAR-280041ERL x 2 for front
I've heard they work great, could you please help out with the correct size to order? I found a bunch of choices on this site for the solobleeders. Thanks a bunch.
http://www.mpsracing.com/products/Earls/Solo-Bleed.asp
Tech Info Resource
They're way overpriced on the site you linked to.
Tech Info Resource
Those part numbers are for the IS350. The IS250 might be different. The IS-F is definitely different.
Tech Info Resource
You can't be talking about the "amazing Mity-vac." Those things are a joke.
I have a real vacuum pump for vacuum:
