after installing Ball Joints issue? ?
i just installed front lower left/right ball joints on my car. i noticed that my steering wheel kinda pulls to the right . .. .why is this ? im about to install Daizen steering rack bushings within the next two weeks or so , should i get my car aligned after? or did somthing go wrong on ball joint install ?
there are no noises coming from the front of car everything seems to work fine only thing is the wheel pull . . .
thanks
thanks
Your car needs to be aligned since the pivot points are in their true location again. Probably should install bushings first and then have it aligned. IMO I would go ahead and get it aligned now and then install bushings unless your old bushings are really deteriorated.
i think im going to wait till the bushings come in and then do the alignment , the bushings are pretty beat up right now . .. and they should come in tommorow (sat.) , i guess next weekend is project week ! . . .
thanks !!
tony~
thanks !!
tony~
If your tires are any good, I wouldn't drive it until the alignment. After I installed the lower ball joints, my alignment was way out. It won't take long to eat up your tires in that condition. Just my 2 cents.
in my case after I replaced my ball joints and tie rod ends my steering was fine, i guess i got lucky. the only problem is that my steering wheel is out of sync with the front wheels, like my hand would be in the 11'oclock position if I want to go straight but I have no pull if I let my hands go of the steering wheel. I'm also planning to install the daizen control arm bushings soon and then get an alignment. It's been 2 months since i installed my balljoints and tie rods
agreeed, it took me a few weeks to get an alignment because i was lazy and wanted to wait for until I had time to fully lower the coilovers, during that time my tires got real bad. Less than 10k miles and fronts are already needing to be changed.
Newchapter
04-10-10 03:10 AM
