LS400 brake on 2nd GS
I am in the market for a set of rim. Here is what i found
Volk racing SF challenge
Front 19x8.5 offset +42
Rear 19x9.5 offset +40
I am going to install LS400 caliper soon. Anyone know will those rims will clear the LS400 caliper? Will i get fitments issue for that offset.
Every input would be appreciated
Here is the picture of SF challenge
Thanks to GS FONZy
I found this table on the Rays website.
http://rayswheels.co.jp/cgi-bin/cgi2...?modelName=SFC
please give me some more info.
first, how do you want your wheels to fit and what type of tire are you planning on using. no mods to fenders, some mod, flush, stretch, ect. If the wheels are used or this is the only offset available, than there is always spacers if you wish to push them out a bit.
on the table that is provided, anything on table A & B will clear BBK,
so those will clear.
@GS FONZy, I am very appreciated your help
I just want to wheel fit to outside around 10mm more than the stock. I afraid to do any fender mod. I am currently on the Tanabe NF210 and KYB GR-2 set up, basically the font dropped around 1 Inch, i am thinking to run 235/40/19 and 265/40/19. I am worry about will the front tire gonna hit the upper arm control and will i get into the fitments issue on the rear tires?
you don't have to worry about that size fitting because i don't think they make it. This is the set up i recommend 245/35/19 & 275/30/19 and since your not going to need to stretch the tire, i would recommend going with Nitto Extreme555. These tires run a little taller than others and are square on the rim, so it will protect it from curves, lightly.
Where did you get your RCAs? I knew a site that had them, but i lost the link. I too am thinking about the LS BBK. Supra BBK is just too heavy
i am at my friend house right now, i will give you the link when i get home.
Thanks for the help GS FONZy
