Warning To All 2nd Gen Gs Owners
#61
There are a lot of damage balljoints but no report of accident caused by balljoints. I copy the recall from 97 Lexus GS300 recall on lower balljoints:
1997 LEXUS GS300 Recall ID from NHTSA: 99V125000
Auto Recall Date: 19990519
Vehicle Component: SUSPENSION:FRONT:CONTROL ARM:LOWER BALL JOINT
Estimated Vehicles Affected: 2737
1997 LEXUS GS300 Defect Summary:
VEHICLE DESCRIPTION: PASSENGER VEHICLES. DUE TO INADEQUATE LUBRICATION OF THE INSIDE OF THE LOWER BALL JOINTS, EXCESSIVE WEAR CAN OCCUR CAUSING DAMAGE TO THE LOWER BALL JOINTS. SEPARATION OF THE LOWER BALL JOINTS FROM THE STEERING KNUCKLE ARMS COULD OCCUR.
Defect Consequence:
THIS CONDITION COULD LEAD TO A LOSS OF CONTROL OF THE VEHICLE, INCREASING THE RISK OF A CRASH.
Remedy:
DEALERS WILL REPLACE THE LOWER BALL JOINTS.
Notes: TOYOTA MOTOR CO., LTD.,
Defect Consequence:
Remedy:
#62
The updated ball joints are from 03+. Your GS are from 03 w/ only 44K. You might be the only one reported of bad ball joints.
#65
I have had several conversations about these failures. There is no doubt that they are occuring BUT what is it that is breaking? Are they truely breaking or are they wearing out I know that seems like an odd statement BUT. If they are breaking then that shows material problems. If they are wearing from being ackwardly binded then that would be a design issue.
The only theory me and my friends can come up with is that the joint is rubbing itself thin and then breaking. Can anyone come up with a mode of failure for these joints?
Kevin I would love to see a close close up picture shot of the broken peice of the ball joint.
I have replaced mine at 78k, I could not tell the difference before / after. I could not feel any slop in the joint I have the old ones and I am actually sorry I wasted my time and more so money replacing them.
I never heard any clunks or squeeks etc. I was just scared my wheel would end up 90 deg out of turn.
Thanks for the DIY who ever that was it helped a great deal++++
B
B
#69
Thats crazy ! The same thing happened to me in my GS400 going about 30 mph. I was a half a block away from the toll where I was gonna get on the highway because I was late for work...Scary? I had the same damage done to my fender. Does anyone know what else to check after this happens to your car?
#71
j.tom:
I posted the link for the DIY ball joint replacement on page 4 please go look for it. It should have pictures on there.
bmpiazzola:
I attached a close up picture of the ball joint for you hope it helps if not let me know and I'll try to enlarge it if I can. Also let me know what you've come up with.
g4inrich:
This happend to you to? Where it accutually gave out like mines did? If so post some pictures and we'll take in acct. what happend because we're trying to bring it up to Lexus's attention.
If anyone know someone that this had happend to refer them to this post. Thanks.
bmpiazzola:
g4inrich:
#72
So how long can you drive while after you start to hear the creaking? I noticed a small creaking a couple weeks ago, and then the loud creaking when I turned the wheal all the way in a direction. I have a appt to get it fixed, but that isn't for about a week and I don't want to be stranded.
#73
#74
Oh yeah, I also got quoted $1400 from the dealership. This must be the upper and lower assy, since I don't think even a dealership would charge that much to replace two lower ball joints that cost $60 each. Can this problem be fixed with just replacing the bottoms?
I am having a mechanic look at it, but I want to have as much info as possible.
