L-Tuned Rims with BBK (Supra) fittment?
I need some help, PLEASE,
I want to by the BBK from Carson,
http://www.l-tunedparts.com/product/?id=1474
BUT, my question is, will these fit my L-Tuned Superturismo Rims,
there 17x8, I dunno the offset ill have to look at it when i take off a rim but it looks to me as if there is a lot of space for clearance, but still dont want to risk it, as far as the rotor goes, I see its bigger i think its 13in.
Found the offset for the superturismos on an other thread and it said
offset is +50,
I really hope it works but if not, what would i need to get it to fit, what kind of offset should i look for or what type of rim should i look for to get the BBK working for me, or can i even use spacers for my existing rims?
I found some rims 19x8.5 +45 will those work with this setup???
offset is +50,
Sometimes the fitment isn't set in stone because it can be due to the design of the wheels themselves. But I normally if you measure at least 65mm from the edge of the brake rotor to the inside edge of the wheel spoke then you should be fine. As for the 17inch part, I think that should be alright, since SupraTT had 17inch wheels. Wasn't there a topic somewhere around CL that had a huge database of wheels with information regarding BBK fitment? Either its on CL or SoarerCentral.
XenonES3
Wheels, Tires & Brakes Forum
07-17-03 07:19 AM
