Do we have screws that hold our brake discs to the hub?! I just had my rotors.....
Old 06-05-07, 08:47 PM
diamondmit
diamondmit's Avatar
Exclamation Do we have screws that hold our brake discs to the hub?! I just had my rotors.....
....replaced, and NONE of the rotors, front or rear, are attached to the hub. With the wheels off of the car, I can wiggle the rotor all around (forward and back until the lug bolts stop the rotational progress, and in-and-out like a spinning top about to topple over). WTF!!!!?
Please let me know ASAP before I storm into the repair shop in the morning!
Thanks,
DD.
Old 06-05-07, 08:57 PM
Kharizma
Kharizma's Avatar
um. i think it's supposed to do that?
when i take off my wheels they just come off lol... i don't think they're supposed to be screwed down to anything.
Old 06-05-07, 09:00 PM
diamondmit
diamondmit's Avatar
Default Hmmmmmmmmmm. Well, that's different then.
I guess I'll have to be circumspect as I discuss this in the morning. I'll try to call the dealer in the morning.
Thanks!
dd
Old 06-05-07, 09:24 PM
GSteg
GSteg's Avatar
That's normal. The rotors are held on when you put the wheel back onto the car. The rotors are sandwiched between the wheel and the wheel hub.
KRGS4
KRGS4's Avatar
Yes. This is normal.
1. The Wheel(rim) torqued down to the Hub holds the rotors to the car.
2. With the Wheel off... the rotors can wiggle...but not come loose because the Calipers/Pads and Stud Bolts are still holding them up.
*the only rotors that don't wiggle around are...
...the old rusty rotors that have rusted and seized on to the hub...
Old 06-06-07, 07:46 AM
carbongs
carbongs's Avatar
^very good point. i even go as far as putting anti-seize on the hub and back of the rotor to keep them from heat fusing together. you may want to put some on the threads of the studs too. but yeah it is normal for them to wiggle when the wheel is off
Old 06-06-07, 08:09 AM
Ronsully
Ronsully's Avatar
some cars have small screws that hold the rotors on; however, i think those screws are on there to make the original assembly easier (ie - when the car was manufactured).
Old 06-06-07, 09:36 AM
diamondmit
diamondmit's Avatar
Default Thanks guys - you are right (dealer confirmed, although it appears that you didn't...
...need that confirmation :-)
thanks for the replies!
dd
BTW, my BMW has two set screws to hold the rotor onto the car, and the LS, gen 1, had them also. I didn't find a rotor changing website and couldn't verify this until the morning.
tedsterb
02-16-16 08:33 AM
Och
Suspension and Brakes
09-10-11 07:06 PM
Cimf19
05-23-11 06:45 AM
diamondmit
06-06-07 05:42 AM
tmorales
04-05-04 10:23 AM
Quick Reply: Do we have screws that hold our brake discs to the hub?! I just had my rotors.....
