OEM Brake Rotors Replacement Brembo or Rotora
Old 10-23-06, 02:45 PM
shftup
shftup's Avatar
Default OEM Brake Rotors Replacement Brembo or Rotora
Hey guys - I think i will need at least 1 new rotor(drivers front), have an appointment this Thursday @ dealership. Qusetion is, if thats the problem (plenty of pad left, ball joint are rock solid, no bent wheel and it make a 'thud'n as the wheel rotates, but goes away if a brake medium to hard, it always there, but as i brake harder then noise goes away).
So, anyways, here is what I am looking at for replacement
Rotora - http://www.l-tunedparts.com/product/?id=506
Brembo - http://www.tirerack.com/brakes/brake...ar=&perfCode=P
Or, would you just choose OEM's?
So, if you have real world experience, let me which you would choose and why. I am really only looking for a OEM replacement, not really looking for drilled/slotted.
Thanks in advance.
Old 10-23-06, 03:29 PM
GUNRU-GS4
GUNRU-GS4's Avatar
I bought the slotted Rotoras from l-tunedparts.com and they have been good as an OEM replacement. Plus the hats are coated so they won't rust and look like crap.
Old 10-23-06, 05:54 PM
shftup
shftup's Avatar
Thanks, i have the Akebono pads like you, so that a good to know that this setup works well.
Old 10-24-06, 08:11 AM
SloGS3
SloGS3's Avatar
I have slotted Brembos on mine with Akebono pads and I like them so far. If you are not looking for slotted/drilled ones, then I would say go with whatever is cheaper. OEM might cost you more than Brembo blanks, I would go with Brembo in this case.
Old 10-24-06, 03:37 PM
shftup
shftup's Avatar
so, i got the car into the dealer, and they checked everything, and still nothing.
wait, hold the phones......i got there to pick it up, and we talked, then I was like, OK, time to order new rotors, lines, so forth.
Then, I asked, did you re-torque the wheel - Master Tech, uhm, nope. Might as well try that before I make the order - when for a drive.....and BOOOOOM. that was it, no more sounds, just pure perfection.
Thanks for all the help.
andygs300
01-26-12 12:21 AM
hieutp
Suspension and Brakes
32
07-11-10 07:21 AM
Mr Aristo
GS - 1st Gen (1993-1997)
11-21-07 01:51 PM
400 Degrez
01-26-07 05:40 AM
Quick Reply: OEM Brake Rotors Replacement Brembo or Rotora
