Tein S-tech coil dimension
Old 09-12-06, 11:46 AM
HI98GS
HI98GS's Avatar
Default Stock rear spring dimension
Does anyone have a set of stock rear springs for the 2nd gen GS? I really need to get the coil dimensions (inner and outer diameter) I wanna try to fabricate an upper isolator (the rubber ring on the coil which comes in contact with the supension support)
Thanks
File Type: pdf
Old 09-12-06, 08:06 PM
DoubleWhoosh
DoubleWhoosh's Avatar
what exact dimensions do you need?
Sorry, busy trying to troubleshoot a big project for next week, hopefully I can get back here to help you out!!!
Old 09-12-06, 11:59 PM
HI98GS
HI98GS's Avatar
I want to get the overall diameter of the spring and the inner diameter. I am trying to purchase an isolator that like this, but i need measurements. this is made with polyurethane. I would also like to change the rubber bushings on top of the strut/hat. If you happen to know the inner diameter of the bushing as well as outer diameter maybe I could find one.
Thanks
Old 09-13-06, 12:09 AM
HI98GS
HI98GS's Avatar
FYI, it was this part and the other part which I am trying to change that was giving me the clunk noise from the rear suspension. So anyone who would/can assist with the dimensions would not only get my appreciation but may also help out others with the same problem that haven't found the fix.
The whole rear suspension was taken out and inspected (upper and lower control arms, sways etc) and this is where the sound was isolated to.
Old 02-06-12, 10:39 AM
RamAirRckt
RamAirRckt's Avatar
If you are still on the forum HI98GS, did you ever get the dimensions?
I am looking for front and rear spring stock dimensions if anyone has an stock spring off they can measure for me.
KangstaxD
Suspension and Brakes
17
04-03-18 04:06 PM
RoninEng
05-10-12 11:28 AM
ItWasntMe
03-01-10 05:37 AM
newyorksc
20
08-03-09 10:20 PM
Salil022
11-04-05 01:52 AM
Quick Reply: Tein S-tech coil dimension
