You don't need to. Just cut the heat shield a little bit and bend it back. Everything else bolts up fine. I'm posting up a DIY on my site in a day or so.
spacers for your wheels? if so, you should find out if your current wheels are bbk compatible.
low/med/high disc
^^ What Corky said... you need loads of clearance for these within your wheels. High disk fittment, even then it sometimes doesn't fit and you need spacers (as I did with mine)
