How to install brake rotors ??? GS400
I just bought Brembo brake rotors for my gs400... but don't know how to install.. and don't wanna pay 70-80 bucks a piece to install.. i'd rather do it myself... anyone got instructions w/ pictures???
Thanks!!!!!
Thanks!!!!!
ok from memory
loosen the lugs
jack up the wheel
take of the wheel
with a 14mm socket/wrench take off the caliper
with a 17mm /18mm ? take off the caliper bracket
rotor comes off
is the rotor stuck ? with some well placed hit it will pop off
still stuck ???
there should be threaded holes ,
get a bolt that fits and start threading it in
It should pop off then
If i made a mistake ..then some one pleae correct me
loosen the lugs
jack up the wheel
take of the wheel
rotor comes off
still stuck ???
Originally Posted by TLW
ok from memory
loosen the lugs
jack up the wheel
take of the wheel
rotor comes off
still stuck ???
loosen the lugs
jack up the wheel
take of the wheel
rotor comes off
still stuck ???
TLW do you know how to replace the spindle/axel hub?
ok from memory
loosen the lugs
jack up the wheel
take of the wheel
rotor comes off
still stuck ???
loosen the lugs
jack up the wheel
take of the wheel
rotor comes off
still stuck ???
I believe 17mm applies to all four calipers, when you reassemble torque the rear calipers at 77 ft/lbs and the front at 87 ft/lbs, if you bleed the bleeder screws spec is 8 ft/lbs. If you haven't done this before take two lugs and install them on opposite sides of the rotor to get it fully seated before trying to reinstall the calipers, good luck.
I used to have a Cutlass and it had the rotor which used to ride on the spindle. The rotor assembly looked like a hat.
Salim
Originally Posted by carmcanc
There are pics here from BANANAGS.....
http://lexusmodz.netfirms.com/
