Daizen Bushing Install Notes...
I had my mechanic install the Daizen kit today along with new outer tie rods. Total time for him was 6 hours working alone. He said he lost at least an hour as both camber adjuster screws were stuck tight to the metal sleeves. Plenty of heat was required to remove them. Otherwise he said he used an air chisel to remove the stubborn old bushings. He said you could save a bit of time if you had a new bolt set for all the arms. That way you could cut off the old bolts to speed things along. He noted the kit was of high quality, and the added grease was a nice touch. He used a hone on an air drill to hone and smooth all bores before pressing in the new bushings. I didn't notice a huge difference in feel, as only one of the bushing was damaged prior to the installation of the Daizens. My car has 160,000 kilometres on it. The only bad thing about a Lexus is since it is so isolated from any vibrations, it's actually a bit tough to tell when things are loose, or sloppy or damaged. But with my mileage so high, and the price of the kit so nice, it was really an easy decision to put the kit in...
removing the bushings took 30min , removing and replacing castor arms another 30mins
doing the control arms bushing removal should be about the same changing lower control arms takes about 30mins each side
Originally Posted by Neo
Wow. Really Ed? What part took an hour? Swapping the bushings? Everything? Just curious.
6 hours labour @ $50 an hour. Not bad. I was going to do it myself, but decided against it in case I needed a torch..which I don't have. 1 hour is very fast.....do all of your bolts unfasten themselves? I mean...just doing the upper control arms wouyld take an hour all by themselves! Alot of my bolts were absolutely welded on from rust. Perhaps if you car is more garage queen, or if you live in warmer, drier climates your results will be different. I drive my car all year, and in the winter too. Despite the age and mileage on my car, only one bushing was bad. Lexus quality is amazing..
gargage queen my car is not.. this car is daily driven.. i do these things fast because i use a high power air compressor and a 230 ft lb impact gun to crack bolts open with ease...
i study the project and tackle it with a objective in mind..
i have extracted one of my lower ball joints in under 15 mins once when i busted it on the way to work
once you have the method down on extracting the bushing out of the arm , removing and reinstalling on the car is like butter
After a mechanic installed my Daizen bushing kit, I have this alarm light on my dashboard that they can't reset. ABS light is on, VCS light is on and VCS OFF light is on. Did any of this happen on your installation?
exclusive matchup
5% Club. Killing it!!!
I would have to guess ABS sensor also... Especially when changing coilovers etc.... not to pull on the abs sensors.....and when doing brakes.... Unfortunately the ABS sensor is right in the general area where we need to work..... be careful.....
Answering a post about labor on coilovers i paid about 200.00 for less than two hrs to install my Teins...I don't think thats to bad
Tony
Tony
