big brake help
Old 08-03-05, 11:26 PM
theseth
theseth's Avatar
Default big brake help
What is the smallest rim size that will fit over the rod millen big brake kit?
Seth
Old 08-04-05, 12:53 AM
Neo
The One
Neo's Avatar
I believe 17s will fit over the rotors but you need to make sure it has enough space for the calipers.
Old 08-04-05, 12:58 AM
rominl
exclusive matchup
rominl's Avatar
if you get the right design and offset, 17s will fit. the rmm kit is just the supra tt kit. the supra tt has 17s so it fits for sure
Old 08-04-05, 07:42 AM
bluelex
bluelex's Avatar
You need at least a 17 like they said and a lot of space to clear it. a stcok 17 won't work without a spacer I think i read you need at least a 10mm to fit a stock 17 over that kit.
Old 08-04-05, 08:27 PM
Adam2562
Adam2562's Avatar
u need a 15mm to have it fit.. i did this myself on thestock 17's
Old 08-04-05, 08:33 PM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
This is good to know since i have the supra tt fronts Just in case i need to change wheels... 15mm in the front? What about spacer in the rear.. Will it look funny with just spacers in the front? Thanks for the tip
Tony
TRACKMKIII
GS - 1st Gen (1993-1997)
12
12-07-14 01:46 PM
Adam2562
Suspension and Brakes
30
07-06-05 05:23 AM
kyle3481
12-04-03 12:40 AM
Quick Reply: big brake help
