Assist me, please (what is this missing bolt from brakes)
Old 02-23-05, 07:58 PM
the hustler07
the hustler07's Avatar
Question Assist me, please (what is this missing bolt from brakes)
does anyone know the name to the pin missing in this picture, I called Carson Toyota to order the pin, but they sent me a cylinder slide pin. My mechanic told me, this is the reason my car in having a rattle noise from the brakes everytime I hit a bump, its because this pin is missing.
Attached Thumbnails Assist me, please (what is this missing bolt from brakes)-brake.jpg
Old 02-23-05, 08:03 PM
the hustler07
my car is a 98 GS 4, and its the rear brake.
This is a picture of the part, cylinder slide pin, I was sent from Carson.
Attached Thumbnails Assist me, please (what is this missing bolt from brakes)-pin.jpg
Old 02-23-05, 09:13 PM
rominl
exclusive matchup
rominl's Avatar
huh?! that's the rear brake right? if so, then there should be another metal clip piece that does on top to lock everything in place. i wonder if that's the piece that you lost? coz' if that piece is in place it will lock the pin in place
Old 02-23-05, 10:19 PM
the hustler07
yes, romini, this is a picture of the rear brake. When I got the car, it was like that, so i'm not sure what is missing, I thought it was just another pin which belonged there.
Old 02-23-05, 10:46 PM
rominl
exclusive matchup
rominl's Avatar
no, there is a piece of metal piece that goes on top of the pins. then you push it and clip it will hold everything in place
you will definitely need that
Old 02-24-05, 05:03 AM
lexforlife
lexforlife's Avatar
the pin holds the pad in place and the clip that you are missing is the noise culprit its the anti rattle clip and pin
Old 02-24-05, 07:49 AM
the hustler07
Default .
thanks guys i'll just go to the dealership and get it, hopefully they won't rape me.
Old 02-24-05, 09:05 AM
SUPRATRD
Original CL Sponsor since 1999
SUPRATRD's Avatar
Judging from the pics it looks like you need the fitting kit 04948-30071, list is $18.19, comes with the pins,anti-rattle springs
Old 02-24-05, 09:10 AM
alsilverbullet
alsilverbullet's Avatar
If your car is certified they will replace the anti rattle clips and pins on both sides due to a recall campaign on the 98 GS model. I had both of mine replaced at the dealer because one side started to rattle when I would go over a bump.
Good Luck
mehall
06-20-13 12:05 AM
mvbls400
02-08-11 06:26 PM
DRFT103
Suspension and Brakes
04-04-09 03:38 PM
GoCarSc300
01-04-09 11:39 AM
Pianoman72
Maintenance
05-15-03 12:12 PM
Quick Reply: Assist me, please (what is this missing bolt from brakes)
