Break question, Please Help
Mine didn't go to this extent but I can foresee the pedal going to the floor.
If you first look at an exploded diagram of the GS's braking system, it mainly consists of (from the pedal)
- An integrated Master Brake Cylinder/ABS Unit
- Hard lines to the calipers
- Brake lines
- Caliper
- Brake pad
I literally upgraded one by one (starting from the pads) since I thought the initial pedal feel of the stock GS brakes were poop. Then somewhere along the line, I think my booster started to die...which didn't create enough pressure, and ABS freaked out and kicked in a lot under low mu roads.
So since I had replaced almost all the components except for the booster, I swapped the booster (since it is one assy) and I got back my pedal feel. If you can locate one, I highly recommend an 01-05 booster though (one connector will have to be modified however). I have heard that you can disassemble and fix the booster itself but I just replaced the entire unit.
Also, as noted in this thread don't forget to bench bleed the booster itself...which is PITA.
- Brake lines
- Caliper
- Brake pad
Caseoane
01-22-15 01:36 PM
