When changing to L-tuned suspension ...
When changing your springs/shocks, it's a good idea to replace the following as well:
FRONT SUSPENSION
a. upper insulator (includes rubber boot) $17 (so the new spring seats properly and so you don't have to worry about the boot ripping a few years down the road)
If the you suspect the front hats (aka strut mount insulator) are out, you can purchase new ones for $62, but they are unlikely out unless they are currently making a clunking noise.
REAR SUSPENSION
a. upper seat spring cushion $4 (#17; so the new spring seats properly)
b. upper spring cushion $5 (#19 in pic)
c. lower spring cushion $7 (#20 in pic)
FRONT SUSPENSION
REAR SUSPENSION
Originally posted by chrisleX
Hey seattlegs400, any chance to get the part # for those listed above ? thx a lot !
Front insulator: 48157-30040 ($16.25)
Rear insulator: 48257-30060 ($4.29)
Rear cushion (lower): 90948-01062 ($7.39)
Rear cushion (upper): 90948-01063 ($5.06)
Have fun!
Originally posted by LEXISM
question do any of these parts get replaced w/ a 30/60/90k service? cuz i just had my 90k service done and I beleive they check out your suspension ......
The above suspension parts should be good for each original spring/strut installation, and I really woudn't worry about just changing them for the purpose of just changing them individually at 60k/90k etc., unless:
1. I was changing out my suspesion for newer shocks/springs (like some of the others above are doing) or. . .
2. There was an obvious problem with my suspension (leakage from the shock, a blown shock, torn shock boots, damaged shock rods, faulty shock tower (aka strut mount insulator), etc.)
SeattleGS400,
You're the man!
I think you just answered my question here
https://www.clublexus.com/forums/sho...hreadid=128801
Do you think the "rubber boot" I'm talking is the same one you mentioned?
Thx.
You're the man!
Thx.
dubsonlexus
FRONT SUSPENSION
REAR SUSPENSION
FRONT SUSPENSION
REAR SUSPENSION
01, 4815730040, 4825730060, 9094801062, exploded, front, gs400, gs430, is300, lexus, ltuned, rear, suspension, tune, view
