Need Help! ! Trying to wire an FM Modulator
Old Sep 13, 2003 | 01:04 PM
Philly#1 Lex's Avatar
Philly#1 Lex
Default Need Help! ! Trying to wire an FM Modulator
Im trying to hook up a FM Modulater to my existing Nakimachi until i get my new deck. I need to know where i can find the constant power (Green and white) and the ACC power (red) on the deck. I neeed a quick answer thanks!
Philly
Old Sep 13, 2003 | 05:42 PM
jeremyp111's Avatar
jeremyp111
The wires should be coming from the back of the deck. Connect a voltmeter to the pins in the wiring harness to check for power when the car is off to find the constant 12v source and when the car is on ACC or RUN for the other power source. You can also get the power from the fuse block as well. Just use splice connectors to make your connections without having to cut the wires. Should make it nice and easy for ya.
JP
ESeries300
Mar 25, 2011 05:21 AM
antsc300
Mar 31, 2008 01:08 AM
JWS3
GX - 1st Gen (2003-2009)
24
May 18, 2006 03:20 PM
LasVegasGS
Jan 18, 2006 07:49 PM
