1993 gs300 can't get trunk open
Ok so after getting the gifted car (93 gs300) running I'm needing in the trunk. The problem is the security lock is on and I don't have that key appently. The keys were broke off in the ignition and it was changed. So the keys start the car but don't unlock the doors. I have a electronic key with the button that will unlock the doors but won't fit any of the locks. Any help appreciated
You can have a Locksmith match the locks to the key you have so you will have one key for the entire car or you can have the dealer cut a key according to your VIN that will work for the locks on the car but not the ignition.
The sad thing is the previous owner has 2 more keys that should open the trunk and unlock the security lock but god knows where they are. Really hoping for something cheap I can do really I just need to get his stuff outta their. Is their away around the security lock so I could use the button?
I seen this for a sc but if you can get to the lock some way maybe you can unlock it and be able to use your switches again
https://www.google.com/url?sa=t&source=web&rct=j&url=https://m.youtube.com/watch%3Fv%3D2FITcrUPKXw&ved=0ahUKEwj95ZCZvrHSAhVjiVQKHaklDqgQwqsBCFswDQ&usg=AFQjCNF4HsSPYAA9u7el_ALZsk9P-YS6IA
First time Ive tried to post a link I hope it works
Ok sorry haven't had time to repost on this issue. Got the trunk open. I pulled the security lock out and pressed the button on the back. Lock unlocked and trunk opens great thanks guys
