Door Ajar Warning
Old 01-23-17, 12:19 PM
Stotlar
Stotlar's Avatar
Default Door Ajar Warning
My wife's 2005 SC430 has a "Door Ajar" warning going off continuously. Obviously checked the doors, stopped the vehicle and turned off, re-started, same issue. Anyone else had issues with door sensors or possibly a relay of some sort?
Thanks
Old 01-23-17, 12:56 PM
DshngDaryl
DshngDaryl's Avatar
Could the convertible top not be all the way down? One way to tell is if the convertible top button is flashing red
Old 01-23-17, 01:32 PM
Caflashbob
Caflashbob's Avatar
Trunk? Slightly open?
Old 01-23-17, 10:15 PM
texsexlex
texsexlex's Avatar
...I haven't had this issue with the Sc, but did encounter it with an Ls. If you look inside the doorjam, you should see a small rubber boot, there is a button under this cover. When you close the door, this should make contact with the plastic pad, on the inside of the door. The button may need to be adjusted & this should take care of the issue
gs350trev
07-28-14 10:00 AM
ATLSam
IS C
04-13-12 05:27 PM
greg0723
02-15-11 05:11 PM
NoiseFree
ES - 5th Gen (2007-2012)
09-25-07 06:42 AM
enginyr
11-21-01 10:55 AM
Quick Reply: Door Ajar Warning
