2014 ES350 No Nav - Screen Mirroring
Old 01-19-17, 11:37 PM
gggunk
gggunk's Avatar
Default 2014 ES350 No Nav - Screen Mirroring - HELP
HI, I have been figuring out how to mirror my Android / IPhone screen to the built-in display of the 2014 ES350 (No Nav), so that I can push Google Maps screen and audio from my smartphone to the built-in display. From what I can see, there are wiring harnesses available for 2014 ES350 with Navigation that I can use. But, I have been unable to locate any that support the same model without factory nav. Not sure why a factory nav influences screen mirroring, since it is the same display. Can you help me understand if it is possible at all to mirror my smartphone screen (preferably Android) to the built-in display? Thanks in advance for your help.
Last edited by gggunk; 01-20-17 at 08:44 AM. Reason: Modified headline to clarify intent of starting thread
Old 01-20-17, 06:43 AM
lesz
lesz's Avatar
Received 1,010 Likes on 691 Posts
Originally Posted by gggunk
Not sure why a factory nav influences screen mirroring, since it is the same display. .
I don't have an answer to your primary question, but I will point out that the screen on an ES without navigation is not the same screen as that on an ES with navigation.
Old 01-20-17, 08:43 AM
gggunk
gggunk's Avatar
You are right. Having said that, since the rearview camera video feed does show up on the display, and since the display unit can be controlled through the steering and center console controls, I am sure adding a wiring harness to render a second AV feed on the same display (controllable through the steering controls) should be theoretically possible. (and there ends the limit of my tech knowledge. ) I really hope one of you folks can please clarify if it is possible. And if so, how to do it.
JosersRX
RX - 4th Gen (2016-2022)
09-14-16 09:40 AM
cryosurge
NX - 1st Gen (2015-2021)
02-21-16 11:12 PM
Lexi66
ES - 5th Gen (2007-2012)
10-06-14 01:50 PM
BigVIPness
12-29-05 12:07 AM
Quick Reply: 2014 ES350 No Nav - Screen Mirroring
