Shifter cover slide broken ... need pointer(s)
Old 01-19-17, 09:10 PM
salimshah
salimshah's Avatar
Default Shifter cover slide broken ... need pointer(s)
There is a gaping hole near the shifter base. It is the sliding plastic piece that moves with the shift lever.
I traced the part
https://www.lexuspartsnow.com/parts/...975-30240.html
There are DIY that lead me deep enough to what looks like one layer above the broken part.
Has any one replaced the part? Do I hope that I can simply remove the next layer without taking the shifter out.
Help.
Salim
Old 01-19-17, 09:31 PM
ThomasGS4
ThomasGS4's Avatar
You will have to remove the "PRNDL" cover, which is held on by 4 tabs. The piece you are looking to replace is attached, but underneath that cover.
Old 01-20-17, 08:48 AM
LexusK
LexusK's Avatar
Mine broke too, but I just left it. Don't think I really need it... do I?
Old 01-20-17, 10:10 AM
salimshah
salimshah's Avatar
Exactly .. but what does it take to get underneath?
Salim
Old 01-20-17, 10:13 AM
salimshah
salimshah's Avatar
Two reasons I would like to fix it:
1. You can drop something in there.
2. If the pieces turn around, they may prevent shifting ,.. then I will have to resort to breaking it up further (more than 2 pieces and the tiny pieces can get in places you dont want.
Reasons not to fix it:
Process is too elaborate
Price of the part (which is not too much)
Salim
Old 01-20-17, 11:49 AM
sakataj
sakataj's Avatar
I traced the part
Help.
Salim
I'm thinking even the moderators on here don't actually search :P
Post # 4
https://www.clublexus.com/forums/gs-2nd-gen-1998-2005/410688-diy-on-changing-center-console-bulbs-tranny-gear-indicator-bulb.html
I
had issues with mine catching so I had to lay it back down again but after that it re-installs just like its removed.
post # 6 shows it removed
Old 01-20-17, 02:56 PM
salimshah
salimshah's Avatar
Wink
Post # 4
I
We are all humans, but I did find the link to change the bulbs/leds, but not how to go one step further.
https://www.clublexus.com/forums/gs-...or-bulb-9.html shows one more level I need to traverse.
Incidentally the link you posted does not work.
Old 01-23-17, 06:55 AM
sakataj
sakataj's Avatar
yeah I accidentally put the I on the next sentence into the HTML
https://www.clublexus.com/forums/gs-...ator-bulb.html
check post 4 and post 6 for your "next level"
gl
Old 01-23-17, 01:23 PM
salimshah
salimshah's Avatar
Thanks ..
I will wing the last part.
Salim
Old 01-25-17, 01:07 PM
sakataj
sakataj's Avatar
Thanks ..
Salim
Salim, I'm not trying to be a smart *** or confrontational but where is there to wing? I clearly show the black slider part off in those posts...
Old 01-25-17, 11:12 PM
salimshah
salimshah's Avatar
I am grateful for the guidance. Once the tabs are pulled out, a layer comes off. There is yet one more layer before I get to the slider. I think I am over thinking the problem ... once I get there, it would be obvious to figure it out.
Salim
ps: It just could be that picture sandwiched between step 6 and step7 , is where the slider is. My mistake as I thought that I need to go one more layer.
Old 01-26-17, 08:16 AM
sakataj
sakataj's Avatar
so on post # 4 after steps 1-5 you will remove the black shifter cover and that piece you want to replace should literally be laying on the top with you to see and it just comes off IIRC
salimshah (01-27-17)
Old 01-27-17, 07:52 AM
salimshah
salimshah's Avatar
Thanks for confirming. It should have been obvious and i I was overthinking it.
Salim
Old 01-28-17, 07:56 AM
sakataj
sakataj's Avatar
Salim
no worries.... if you get a popping, hard to shift issue after changing it go back and read my solution to it from the thread I posted
Old 03-16-17, 05:00 PM
salimshah
salimshah's Avatar
Installed the part last night. The old one was too crisp ... no wonder it broke off. Had to go back and twist the shifter another 180 degrees before Mrs could spot my mistake.
Thank you sakataj.
Salim
Quick Reply: Shifter cover slide broken ... need pointer(s)
