If the rear wheels are larger than the front wheels, how do we rotate our tires?
Old 01-18-17, 06:07 PM
Speed3381
Speed3381's Avatar
Default If the rear wheels are larger than the front wheels, how do we rotate our tires?
Sorry if this is a stupid question lol
Old 01-18-17, 06:12 PM
MustangSal
MustangSal's Avatar
L-->R and R<--L (front and rears respectively)
gth181a
gth181a's Avatar
you don't.
dchar
dchar's Avatar
Unfortunately you don't. So tread life isn't great.
Old 01-18-17, 06:17 PM
badbwoy007
badbwoy007's Avatar
Just happens to be the life with a staggered setup. You will probably end up replacing rear tires first as fronts will wear slower.
Old 01-18-17, 06:32 PM
Mewannalex
Mewannalex's Avatar
My wife MB is staggered, like someone said, L to R or R to L, or you don't, either way it sucks cause life of the tires is diminish significantly.
Old 01-18-17, 06:34 PM
badbwoy007
badbwoy007's Avatar
As much as the life of tires suck, it certainly creates a beautiful aggressive stance. Just can't get the same effect with the same size on all fours. Especially if you're looking to go with the concave look.
Old 01-19-17, 12:12 AM
N1njai
N1njai's Avatar
You don't.
Old 01-19-17, 06:04 AM
Handi
Handi's Avatar
If you do the R to L and L to R, you need to have the tires remounted on the wheels as most tires are directional.
Even if they don't have a directional tread pattern, Radial tires once broken in rolling a direction should not roll in a different direction.
It can damage the belts and the construction of the tire.
Old 01-19-17, 06:13 AM
wickedtaco
wickedtaco's Avatar
Default dubs
Start saving for your tire fund and check the CL classifieds.
Old 01-19-17, 09:45 AM
islandbeef
islandbeef's Avatar
You don't rotate a staggered setup, you shift/flip them.
Old 01-19-17, 01:15 PM
charley95
charley95's Avatar
Back in my Vette days I just bought the same size wheels and tires for the front so I could rotate and get a few extra miles out of the tires. The 95 I had didn't have the same size wheels as the ones that had the optional handling package.
Old 01-19-17, 06:51 PM
kmm
kmm's Avatar
Originally Posted by kitabel
How odd. Currently with expensive Harley-Davidsons "aggressive" is much bigger front tires than rears.
"Aggression" is an emotional state in which mechanical objects do not participate.
Is a 1,000 HP Veyron "aggressive" if it's pink with lace curtains?
1STLXS
09-11-10 01:06 PM
pylee257
08-29-07 12:20 PM
juicij36
Wheels, Tires & Brakes Forum
01-10-06 05:21 PM
SharpCreas
15
10-27-05 01:00 PM
Quick Reply: If the rear wheels are larger than the front wheels, how do we rotate our tires?
