Michelin/ Bridgestone combination
Old 12-08-16, 09:29 AM
Moshiko103
Moshiko103's Avatar
Default Michelin/ Bridgestone combination
Hi everyone!
So I own a 2014 IS 250 F sport RWD for about 4 months now and need to replace my front tires (rear are still in great shape).
After a lot of research I found that the Michelin Pilot super sport are a great tires compare to the Bridgestone Turanza ER33 that I have on them now.
My question, should it be a problem to put new Michelin in front while keeping the old Bridgestone in rear?
P.s I would put Michelin in rear once they wear out..
Thank you for your help!
Old 12-08-16, 11:37 AM
EJ255t
EJ255t's Avatar
you'll have too much grip in the front!! if i were you, id just get the Bridgestones then replace all them once the rear wears out!
the OE tires are ****! you'll have a lot of grip in the front and nothing in the rear lol!!
Old 12-08-16, 12:01 PM
Htony
Htony's Avatar
How can RWD vehicle do that? Is it weight balance issue? Or suspension issue? Shouldn't
new tires go to the rear?
Old 12-08-16, 12:36 PM
computerwi
computerwi's Avatar
Most tire shops will put the new tires on the rear and if you are keeping the staggered configuration, that means they won't do it. It's a stability issue when the rear wheels have less traction than the front and this would be particularly bad for RWD. The stock tires are garbage so it won't hurt to replace them early. I'd strongly recommend replacing all four.
Old 12-08-16, 12:42 PM
EJ255t
EJ255t's Avatar
yeah, most tire shops will place the new tires in the rear, unless you have a staggered setup. but like the OP posted, he wants to install PSS....he'll have a lot more grip in the front!
i would just replace all 4 tires now with PSS
Old 12-08-16, 01:08 PM
Moshiko103
Moshiko103's Avatar
Thanks guys for the fast responses.
I am going to keep the current setup (staggered) and really all 4 tires are in good condition as far as tread but one in the front got hit and you can really see the inside metal area..
And I know I can't replace only one so I decided to replace both and keep the other good one as a replacement.
Now you guys suggest to replace all 4, I'll be bummed to do so only because of one bad tire.
Thinking about getting the same ER33 for the front and wait until they all wear out about the same time.
Any other creative solutions?
Old 12-09-16, 07:49 AM
4TehNguyen
4TehNguyen's Avatar
buy new tires, sell good pair of ER33, forget ER33 ever existed, youll thank us later. They are horrible tires
Old 12-10-16, 06:37 AM
Aleriance
Aleriance's Avatar
Do yourself a favor and do not purchase ER33's. They really are some of the worst tires that have ever hit the road. There is no such thing as having "too much grip in the front" like other have said, unless you're flooring it into every turn...
I would get the Michelins for the fronts right now (make sure they're the same size as factory) and when you can, replace the rears with Michelins. You'll have no issues. You're welcome.
vb9594
10-24-20 04:07 PM
Spiro
GS F (2016-present)
09-29-17 03:22 PM
jfw980
10-28-15 09:27 AM
gregj28
05-03-15 07:26 AM
Defratos
IS F (2008-2014)
13
04-29-15 03:19 PM
Quick Reply: Michelin/ Bridgestone combination
