Brakes and Rotor Replacement
Old 12-07-16, 11:36 AM
aator
aator's Avatar
Default Brakes and Rotor Replacement
I'm relatively new to DIY's - I need to replace my brakes and rotors, I tried to purchase a set of EBC Stage 11 Brakes but they can't seem to tie it to the right brakes set asking where my vehicle was manufactured (It's Japan) and what the FMSI# is, but I can't seem to figure that out.
Would anyone have an idea of what the FMSI# is?
Thanks.
BTW my vehicles a 2010 IS250 AWD (and manufactured in Japan if that matters)
Old 12-07-16, 01:46 PM
flowrider
flowrider's Avatar
Received 1,943 Likes on 1,369 Posts
AFAIK all IS's are made in Japan. As far as FSMI. Anyone asking you that is silly. It means:
http://www.utilgroup.com/en/util-gro...ards-institute
And who is they? Get the lexus PN for your brakes and cross reference it to the brand you want.
Lou
Old 12-08-16, 10:32 AM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
2009-2013 IS250 AWD:
USA-Spec:
Front Pads FSMI: D908
Front Pads EBC Ultimax OE: UD908
Front Pads EBC Greenstuff: DP21642
Front Pads EBC Redstuff: DP31642C
Front Pads EBC Yellowstuff: DP41642R
Front Rotors: 7388X (Need prefix for type of rotors)
Front Stage 11 Plain Kit: S11KF1276 (Includes Greenstuff pads and RK rotors)
Canada-Spec:
Front Pads FSMI: D1178
Front Pads EBC Ultimax OE: UD1178
Front Pads EBC Greenstuff: DP21772
Front Pads EBC Redstuff: DP31772C
Front Pads EBC Yellowstuff: DP41772R
Front Rotors: 7223 (Need prefix for type of rotors)
Front Stage 11 Plain Kit: S11KF1355 (Includes Greenstuff pads and RK rotors)
Canada and USA-Spec:
Rear Pads FSMI: D1113
Rear Pads EBC Ultimax OE: UD1113
Rear Pads EBC Greenstuff: DP21586
Rear Pads EBC Redstuff: DP31586C
Rear Pads EBC Yellowstuff: DP41586R
Rear Rotors: 7391 (Need prefix for type of rotors)
Rear Stage 11 Plain Kit: S11KR1127 (Includes Greenstuff pads and RK rotors)
Rotor Prefix: RK (OE-style), GD (Drilled/Slotted), USR (Slotted), BSD (Multi-fine Slotted)
Hope that helps!
Jeff
Old 12-08-16, 10:50 AM
aator
aator's Avatar
Thanks both for the replies.
What does it mean if it's US spec vs Canada spec (considering they're manufactured in Japan)?
Would I be getting the Canada spec considering it was purchased in Canada (and manufactured in Japan)?
I got the OEM part codes from the dealer:
04465-53040 Pad
04945-53050 Shim Kit
43512-30310 Rotor
04466-53010 Pad
04946-30110 Shim Kit
42431-30280 Rotor
Thanks!
Old 12-08-16, 12:15 PM
Jeff Lange
Keeping it Real
Forum Moderator
Jeff Lange's Avatar
US-Spec versus Canada-Spec is where the car was destined for, where the car was built isn't relevant (they're all from one of two factories in Japan). If it was sold new from a Lexus dealership in Canada, then it will be Canada-Spec.
The part numbers you listed are for Canada-Spec.
Jeff
GSinTN
02-08-19 02:04 PM
FASTEDDY
Suspension and Brakes
04-16-11 10:40 AM
Stage3
06-04-09 10:58 AM
LEXBOGGY
05-31-04 03:14 AM
robbsneak
Maintenance
07-02-02 06:10 PM
Quick Reply: Brakes and Rotor Replacement
