NX - 1st Gen (2015-2021)
Tize size: 245 at the front and 275 at the rear
Old 12-04-16, 02:46 PM
Sondoan
Sondoan's Avatar
Default Tize size: 245 at the front and 275 at the rear
Hi, just wondering, any problems if i use that for 20 inch wheels? my car is lexus nx200t fwd
Old 12-04-16, 06:14 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Depends your rim specs and tire profile. If close to my summer set, 265/35/22 all around on 22x9 +38, your setup should be fine.
Old 12-05-16, 03:41 AM
Sondoan
Sondoan's Avatar
245/45/r20x9 at the front and 275/55/r20x10 at the back
http://www.koya.com.au/cars/new-sf08-19″-20″-semi-forged-custom-fit/
Old 12-05-16, 09:42 AM
olgzr
olgzr's Avatar
If the tires you listed are the same diameter and only different widths, you should be ok. If the diameter is different, it could cause issues with the antilock brakes, antiskid and other systems.
Old 12-05-16, 11:48 AM
GS3Tek
GS3Tek's Avatar
http://www.koya.com.au/cars/new-sf08...ed-custom-fit/
These sizes are meant for a RWD suv, not for a FWD.
Get something where it's squared, same for front AND back like echo mentioned above.
Get the 245/45/20 front and back. It's oem like a venza.
Old 12-05-16, 02:27 PM
Sondoan
Sondoan's Avatar
Old 12-05-16, 05:56 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
275/55 is way too large in diameter. 55-series is a typo? Expecting 40. A 10" wheel at back will be tight with a low offset (too much poke and hit the fender) or a higher offset can rub inner suspension. Perhaps a +40 might work and if it does it's by 1-2 mm...
Old 12-05-16, 05:59 PM
Sondoan
Sondoan's Avatar
275/55 is way too large in diameter. 55-series is a typo? A 10" wheel at back will be tight with a low offset (too much poke and hit the fender) or a higher offset can rub inner suspension.
sorry, it is 275/40
mase929
09-18-11 06:03 PM
I8ABMR
10-03-07 12:13 AM
dle
07-06-07 03:57 PM
photoguy
11-17-06 02:20 PM
qlex56
Wheels, Tires & Brakes Forum
03-15-06 09:42 PM
Quick Reply: Tize size: 245 at the front and 275 at the rear
