Stored 2nd set of TPMS sensors question...
Old 10-27-16, 01:04 PM
doodlebug
doodlebug's Avatar
Default Stored 2nd set of TPMS sensors question...
When you put the winter tires back on the car and you have saved the sensor id's (ATEQ), do you have to put the wheels/sensors back in the same location that they were in when they were taken off? For example, right front wheel needs to go back to the right front, or will the computer pick up placement and recalibrate the new location?
Old 10-27-16, 03:39 PM
Answer
Answer's Avatar
nope, but do a reset/relearn so the pressures are at the correct position in the cluster.
the reset button is hidden under the steering column.
Old 10-27-16, 04:09 PM
doodlebug
doodlebug's Avatar
Thank you.
Old 10-28-16, 05:15 PM
RocketG35
RocketG35's Avatar
What there's a physical reset button under the steering column??? I thought 3IS didn't have that. Where is the button????
Do you need to do this when you install new TPMS + update the config via OBDII? I could never get my car to read the new TPMS - I took it to a shop and they couldn't do it either...but they said their Techstream software was out dated. I tried the Carista Beta and couldn't get it to work. I stored the new codes - when I pull the data it shows the codes are stored - but it won't read it.
Old 10-28-16, 09:23 PM
otakusan
otakusan's Avatar
Beside the OBD2 plug.. if you still can't find it, look on the owners manual, there's a pretty good diagram to show the location
Old 10-28-16, 10:26 PM
RocketG35
RocketG35's Avatar
thanks. I found it. It's still. It working for me though. :/
Javad
11-14-18 11:36 AM
NTH
GX - 1st Gen (2003-2009)
12
01-05-15 05:03 AM
NikonGuy
12-07-14 10:03 AM
Nanook
RX - 3rd Gen (2010-2015)
11-03-14 09:10 AM
SPNinjA
Wheels, Tires & Brakes Forum
04-26-11 09:02 AM
Quick Reply: Stored 2nd set of TPMS sensors question...
