1996 Lexus LS400 - idle problem
Old 10-13-16, 09:41 AM
vger6262
vger6262's Avatar
Exclamation 1996 Lexus LS400 - idle problem
My 1996 LS400 has an idleing problem. When I start the car sometimes the engine goes into revving mode. Can someone help me please.
Old 10-13-16, 11:09 AM
Banshee365
Banshee365's Avatar
https://www.clublexus.com/forums/ls-...capacitor.html
Old 10-13-16, 02:32 PM
winter4w
winter4w's Avatar
I had a similar issue with mine. My car would act normal until it was idle. It will then would rev up and down and would keep on revving until I moved again. I took it to my mechanic and he said it was the idle control valve. It is expensive new $500+ when I looked so I went on eBay found one for a good price. They put it in and bam issue was fixed
I believe the part# was 22270-50020. Hope this helps
- winter4w
Old 10-13-16, 08:51 PM
Banshee365
Banshee365's Avatar
IACV's RARELY fail.
Old 10-13-16, 11:24 PM
winter4w
winter4w's Avatar
Originally Posted by Banshee365
IACV's RARELY fail.
I know but I thought I may chip in in case that may be the issue
Old 10-14-16, 08:32 AM
dicer
dicer's Avatar
The good thing about having a car with OBD2 is you can, have it scanned, or get a scan tool that will read real time. Not a code reader. The best thing to do is have a good outfit with a quality 2 way scan tool (bidirectional) check it out. Then its not so much a guessing and parts swapping game. The tool should be able to run the various valves and check the various sensors, to see what affects the abnormal operation. Those scan tools are not cheap and run anywhere from $1000. to $10,000.
Old 10-15-16, 05:54 AM
easyrider9
easyrider9's Avatar
Is it only on start? Does it calm down after a couple of minutes?
Old 10-21-16, 09:46 AM
vger6262
vger6262's Avatar
It does not stop.
Old 10-21-16, 12:25 PM
dicer
dicer's Avatar
Go buy a maxi das from harbor freight, and then you can operate the idle control system and see if that's the problem. Then operate the egr system. Read fuel trims etc.
Old 10-22-16, 09:42 AM
RA40
RA40's Avatar
Have any codes read and let us know. Some suspicions though any codes or absence of them relays a starting point for us.
Sadim1
04-11-16 02:25 AM
LScowboyLS
22
01-30-12 11:48 PM
k.agbayani
06-11-09 06:45 AM
thebaum
02-27-09 10:44 PM
Quick Reply: 1996 Lexus LS400 - idle problem
