NRG Hub turn signal problems
Hey I recently installed a Momo Wheel and an NRG hub and quick release. I removed the clockspring and there are three small buttons that come out of the turn signal mechanism that should go into the grooves in the back of the NRG hub. The problem is the buttons on mechanism are on somewhat of a spring loaded piece that doesnt put enough pressure on the back of the hub to let them stay seated. So when I turn the wheel the turn signal cancel function will work once and then not again. Im not too sure how I could fix this.
melon
ES - 5th Gen (2007-2012)
06-02-10 07:18 AM
