Windshield fluid reservoir help
Old 09-25-16, 10:23 PM
katsu50
katsu50's Avatar
Default Windshield fluid reservoir help
Anyone have experience replacing the windshield fluid reservoir? I found out mine is leaking after trying to replace the fluid when I got a warning light, only to find a huge puddle under my car seconds after. Any tips would be greatly appreciated.
Old 09-26-16, 03:22 AM
Bichon
Bichon's Avatar
It may not be the reservoir. Have you had the driver side headlight bulb replaced, or had other work done in that area? The reason I ask is that the washer fluid filler cap and hose may have been removed to do that work, but not replaced correctly.
Old 09-26-16, 01:09 PM
Gville350
Gville350's Avatar
^Or...it could just be leaking from where the pump meets the tank. Never had this issue myself, but it COULD BE as simple as an O-ring between the pump and the tank.
Old 09-27-16, 06:00 PM
katsu50
katsu50's Avatar
Think it might be the O-ring, since I never had any work done for the the front. Ill check it out, thanks for your 2 cents.
mikepgs350
05-13-19 08:51 AM
Mobius1
03-23-19 08:45 AM
thegov3
12-24-13 11:11 AM
WiteCastle
10-21-12 06:12 PM
JZCHAOS
RX - 1st Gen (1999-2003)
17
10-13-08 07:09 AM
Quick Reply: Windshield fluid reservoir help
