2011 GS350 'hooting' sound at 60mph
Old 09-25-16, 02:28 PM
deltabravo
deltabravo's Avatar
Default 2011 GS350 'hooting' sound at 60mph
My 2011 GS350 makes a 'hoot' sound at certain speeds and throttle openings. It's particularly noticeable at 55-70mph and very slight throttle opening. Press the gas a bit further and the sound immediately stops. Let off the gas, same result. The sound is constant, so it might more accurately be called a 'whooooo' sound. And the tone goes up and down with speed.
I don't notice it at all at lower speeds. It's possible that the tone is too low for me to hear. I also don't notice it above 70mph though, and the tone would definitely not be too high if it were still there.
I thought it might be that weird plastic box hanging off the intake tube, but I removed it and still hear the sound.
Any ideas?
Old 09-26-16, 11:54 AM
Sodium
Sodium's Avatar
For starters, check your air intake system to make sure your intake scoop, air box, intake tube, PCV hose, and resonator are all connected securely and there aren't any holes or cracks in the parts
Also, check the body panels and seals to be sure that they're all intact and where they should be
Old 09-26-16, 01:05 PM
rl9010
rl9010's Avatar
Sorry couldn't resist...
Old 09-27-16, 12:20 AM
Sodium
Sodium's Avatar
Originally Posted by rl9010
Good point, could be that Bubb Rubb somehow got stuck in OP's airbox
Old 09-28-16, 03:53 AM
deltabravo
deltabravo's Avatar
LOL at the video.
I had the engine cover off and examined the intake stuff. It's all good. No Bubb Rubbs in there.
I can see how a body panel might make the sound but I don't see how that would vary with throttle opening.
Any other ideas? I'd be surprised if I'm the only one with this sound. So far every other noise I've chased down on the car has been figured out by somebody, somewhere, before me.
Old 09-28-16, 08:56 AM
Sodium
Sodium's Avatar
Hmm well if it's not from the intake, you may have an exhaust leak
EDIT: If you live in a county/state that puts a lot of salt on the roads/freeways in the winter, you may well be hearing a pinhole leak. I've seen this problem discussed here before, usually by people from your neck of the woods or Canada. There's a heat shield on the pipes between the primary and secondary cats – salt can get stuck in there and if it sits there for a while, it can rust right through the pipe.
Old 10-09-16, 02:16 PM
deltabravo
deltabravo's Avatar
Ooog, exhaust leak. It's possible I suppose. The car definitely saw winter weather before I bought it.
Old 10-09-16, 04:53 PM
pbxcomm
pbxcomm's Avatar
This would eliminate the transmission: While driving, carefully put the trans in neutural, let the car roll, does the sound stop? While coasting and in nuetural, mildly rev the engine, does the sound change with the revs not vehicle speed?
Old 10-10-16, 11:40 PM
Mesca
Mesca's Avatar
I had an exhaust leak because one of the gasket got pinched and broken in half. Check your exhaust gaskets
Old 10-16-16, 02:30 PM
Mark
Mark's Avatar
Any ideas?
My car did the same. After replacing the alternator it stopped.
Old 10-16-16, 03:54 PM
Gs3500
Gs3500's Avatar
I believe there was a technical bulletin related to the carrier bearing assembly causing a whine noise when coasting. The fix was a simple installation of a washer.
ShowOffGPE
11-20-16 12:47 AM
Boombai
02-07-16 11:14 AM
flattire
11-10-14 05:01 PM
1WILLY1
Performance & Maintenance
11-14-10 06:42 PM
hellasboy
11-15-07 08:32 PM
Quick Reply: 2011 GS350 'hooting' sound at 60mph
