Coolant smell and consuming lots of it but no leaks?
I just bought a 2010 ISF with 108k on it. When I got it home I checked under the hood and noticed the coolant was below the low line. It was in the middle when I bought the car but I figured maybe the system needed to be burped or something so I topped it off. After driving another 50 miles, it was back at the low line. I noticed a smell that I originally thought was just a dusty cabin filter with some old air freshener scent (sweet) but after reading some other threads I'm thinking it's burning coolant. My guess is it's the valley plate? Any ideas on how to tackle this? Unfortunately they have already done all of the recall work (wire harness cover is cracked and duct taped together) so I will be paying out of pocket on this. I'm in Southern California if you have a shop recommendation.
thanks!
thanks!
It may be leaking somewhere where it cant be seen.
Most common issue is the water pump. Need to put it on the rack and examine everything.
They can also do a pressure test on the cooling system.
My $$ is that you have the Valley Plate Leak............... unfortunately your out of warranty so it'll be out of pocket should be around $1300 for the fix. I just had mine fixed about 6 weeks ago and that was my total minus a $500 courtesy credit from Lexus
Not to get off subject. 100k miles is not necessarily a lot of miles on an ISF I bought one with excess of 100k. But without offense taken, did you check on the history of the car first??? Spending what we do on these cars with even higher miles I think everyone needs to be diligent on what they are buying. I think it would be hard fo me to have the previous owner make me swallow they did not know of this issue. Just offering some constructive angles
I bought it from a used car dealer so I may have some recourse but we shall see, they have a 30 day power train warranty but I don't know the details. Even if they cover it, I'm not sure I would want their garage working on my car. The car fax showed that it had been maintained by a Lexus dealer, but I have seen plenty of stories on here that the dealer just tops it off and ignors it unless you really press the issue. Now that I have discovered the master thread on this issue, it is obviously a build quality issue that Lexus should have made a service campaign to save face on. It's not caused by how the car is driven or maintained.
Likely from the valley plate as other have mentioned. You won't be able to see it by just looking down into your engine bay. When I had the leak I couldn't see any pink slime anywhere in the engine bay. I had the dealer take a look under the powertrain warranty and they confirmed the leak. Sorry this had to happen to you. At this point our car ares getting up there in mileage and age and it seems like this issue is happening a lot to ISF owners.
All the systems of Valley Plate leak, this occurred to my F as well lucky still under power train Warranty I was 69780. If you don't have a lot of experience wrenching yourself a working on cars I would not recommend tackling this job find a reputable shop or Lexus dealership, this job is not for the faint of heart you really need to know what you're doing. Goodluck
First off, go to www.lexus.com and click under owners. Register yourself, and insert the Vin number of the vehicle and see the actual thorough report of the service history. Somethings will be gut wrenching because this service history Lexus provides to owners is very thorough. It may come as a surprise to you, is all I'm saying. At least you'll know what's up with your ride. Carfax ain't crap compared to this, trust me.
Second, after you find out what's really up with the vehicle, call Lexus corporate and plead your case. Someone will take note of your concern and pass it along to a service manager in your area. You will be directed to a nearby Lexus dealership for verification of your concern. Either way you cut it, you're going to spend money out of pocket. This way you have a fighting chance that Lexus can cut you a deal and you can meet them 50/50. This will also ensure your vehicle is in good hands and the work can be guaranteed.
I'm aware you're not under warranty and that's okay. Just be honest and polite and more than likely they'll cut you a break. I've had nothing but great experiences in the past doing this. Just recently our 2007 Camry needed a new alternator at approx. 87k miles. Toyota made it clear the factory warranty was only up to 36k. After some pleading, not only did the dealership cover the labor costs but Toyota covered the part. Saving us well over $500. Yes, over $500 they were charging for parts and labor on this. Once again corporate came through, anyways good luck!
107033 MILES
DATE: 08/09/2016
REPAIR# 0173452
REPORTED BY: Lexus of Chandler
SERVICE: BATTERY/COIL SPK PLUG
DESCRIPTION: BATTERY/COIL SPK PLUG ~|~CUSTOMER NOTED VEHICLE HAD TO BE JUMP STARTED, REPLACE AFTER MARKET BATTERY IF NEEDED ~|~TESTED AFTERMARKET BATTERY WITH HAND HELD TESTER, BATTERY FAILED BATTERY HOLD DOWN MISSING AT THIS TIME, RECOMMEND REPLACE ~|~REPLACE BATTERY AS REQUESTED (NOTE : UPPER BATTERY HOLD DOWN MISSING, RECOMMEND REPLACEMENT - WOULD NEED TO ORDER, CUSTOMER DECLINES AT THIS TIME) - CUST DECLINES BATTERY HOLD DOWN REPLACEMENT (MISSING)
SERVICE: DISTRIBUTOR/HDLIGHT/T. SGNL
DESCRIPTION: DISTRIBUTOR/HDLIGHT/T. SGNL ~|~PROVIDE ESTIMATE TO REPLACE RIGHT FRONT FOG LIGHT (LENSE BROKEN OUT) ~|~ ~|~ESTIMATE PROVIDED - PASS AT THIS TIME
SERVICE: YEL FRONT/REAR BRAKE
DESCRIPTION: YEL FRONT/REAR BRAKE ~|~FRONT/REAR BRAKE PAD LINING AT 20-50% REMAINING. ~|~SSK INSPECTION ~|~RECOMMEND RECHECKING AT NEXT SERVICE 89333 MILES
DATE: 06/15/2015
REPAIR# 0154570
SERVICE: AC DUST FILTER
DESCRIPTION: AC DUST FILTER ~|~ ~|~ ~|~AIR CONDITIONING CABIN FILTER, FRONT, R&R (IF EQUIPPED) 08/1
SERVICE: FUEL PRES SENSOR
DESCRIPTION: FUEL PRES SENSOR ~|~PERFORM LEXUS SAFETY RECALL ELF(E2F) AS NEEDED. ~|~ ~|~REPLACED FUEL PRESSURE SENSOR GASKET AS PER SERVICE CAMPAIGN.
SERVICE: IS WIPER NUT INSPECT
DESCRIPTION: IS WIPER NUT INSPECT ~|~PERFORM SAFETY RECALL DLA AS NEEDED ~|~LEXUS RECOMMENDED REPAIR ~|~REMOVED SERRATION PATTERN FROM WIPER ARMS AND REPLACED WIPER ARM NUTS.
SERVICE: ISF COOLING FANS LSC
DESCRIPTION: ISF COOLING FANS LSC ~|~PERFORM LEXUS LIMITED SERVICE CAMPAIGN ELE AS NEEDED. ~|~ ~|~INSPECT AND REPLACE THE COOLING FAN MOTOR SCREWS (INSPECTION PASS)
SERVICE: NON WARRANTABLE OPERATION CODE
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~CUSTOMER REQUESTS BRAKE FLUID EXCHANGE. ~|~NORMAL VEHICLE MAINTENANCE. ~|~BRAKE FLUID EXCHANGE ALL
SERVICE: PENNZOIL PLATINUM
DESCRIPTION: PENNZOIL PLATINUM ~|~CUSTOMER REQUESTS OIL AND FILTER CHANGE USING PENNZOIL PLATINUM OIL AND MULTIPOINT INSPECTION. ~|~VEHICLE MAINTENANCE. ~|~COMPLETE OIL AND FILTER CHANGE USING PENNZOIL PLATINUM OIL MULTIPOINT INSPECTION.
SERVICE: R&R ENG AIR FILTER
DESCRIPTION: R&R ENG AIR FILTER ~|~REPLACE ENGINE AIR FILTER ~|~RECOMMENDED MAINTENANCE ~|~AIR FILTER, R&R 08/11
SERVICE: RED NEEDED SERVICES
DESCRIPTION: RED NEEDED SERVICES ~|~ADVISE ON NEEDED SERVICES - ACTION REQUIRED. ~|~SSK INSPECTION. ~|~CUSTOMER DECLINED.
SERVICE: RED TIRE
DESCRIPTION: RED TIRE ~|~TIRE TREAD DEPTH AT 3MM OR LESS. NEEDS REPLACEMENT ~|~SSK INSPECTION ~|~CUSTOMER DECLINED.
SERVICE: RED WIPER OPERATION
DESCRIPTION: RED WIPER OPERATION ~|~WIPER OPER FELL BELOW FACTORY REQUIREMENTS. ~|~SSK INSPECTION ~|~CUSTOMER DECLINED.
SERVICE: TRUNK RELEASE LEVER
DESCRIPTION: TRUNK RELEASE LEVER ~|~REPLACE INTERNAL TRUNK RELEASE LEVER PER PRODUCT UPDATE DLB ~|~INTERNAL TRUNK RELEASE LEVER MAY BREAK IF NOT PULLED IN THE DIRECTION SPECIFIED ON THE HANDLE. ~|~.3 HRS 3611AA PERFORM PRODUCT UPDATE DLB AS PER INSTRUCTIONS
SERVICE: YEL SUSP COMPONENTS
DESCRIPTION: YEL SUSP COMPONENTS ~|~SUSPENSION COMPONENTS FELL WITHIN MARGINAL RANGE. ~|~SSK INSPECTION ~|~RECOMMEND RECHECKING AT NEXT SERVICE. 52670 MILES
DATE: 09/24/2012
REPAIR# 0275482
REPORTED BY: Arrowhead Lexus
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~PERFORM SAFETY INSPECTION ~|~ ~|~PERFORMED SAFETY INSPECTIONNON WARRANTABLE OPERATION CODE ~|~WINDSHIELD REPAIR 46371 MILES
DATE: 05/17/2012
REPAIR# 0266940
SERVICE: 45000 MILE SERVICE NON WARRANTY
DESCRIPTION: 45000 MILE SERVICE NON WARRANTY ~|~PERFORM 45,000 MILE SERVICE. CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. REPLACE AIR FILTER CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS. INSPECT ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~45,000 MILE SERVICE PERFORMED TIRES FRONT 9/32 REAR 7/32 BRAKES FRONT AND REAR 6MM
SERVICE: LOANER CAR
DESCRIPTION: LOANER CAR ~|~INSTRUCTION/NOTES ARROWHEAD LEXUS HAS PROVIDED A LOANER FOR YOU. WE ONLY ASK A $10.00 PARTICIPATION TO OFFSET FUEL AND MAINTENANCE COSTS. PLEASE RETURN BY 6PM WHEN YOUR VEHICLE IS FINISHED OR A $50.00 RENTAL CHARGE PER DAY WILL BE ADDED TO YOUR INVOICE LO ~|~ ~|~LOANER CAR
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~REPLACE A/C AIR FILTER. ~|~ ~|~REPLACED A/C FILTER(S) 41347 MILES
DATE: 02/09/2012
REPAIR# 0259118
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~MOUNT AND BALANCE TWO TIRES SOP FRONT TIRES HERE ~|~ ~|~INSTALLED TWO TIRES 41104 MILES
DATE: 02/06/2012
REPAIR# 0258812
SERVICE: 40000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 40000 MILE SERVICE NON WARRANTY-NON OEM ~|~PERFORM 40,000 MILE SERVICE. CHANGE OIL AND OIL FILTER CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTER WATER LEVES AND CABLE ENDS. CHECK POWER STEERING FLUID AND TOP OFF AS NEE ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~40,000 MILE SERVICE PERFORMED FRONT BRAKES AT 7MM/REAR BRAKES AT 6MM FRONT TIRES AT 0/32NDS ON INSIDE EDGES REAR TIRES AT 7/32NDS 37495 MILES
DATE: 11/30/2011
REPAIR# 0253805
SERVICE: MISC
DESCRIPTION: MISC ~|~INSTALL S/O FOG LAMP ASSEMBLY ~|~ ~|~COMPLETED 35969 MILES
DATE: 11/03/2011
REPAIR# 0251586
SERVICE: 35000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 35000 MILE SERVICE NON WARRANTY-NON OEM ~|~PERFORM 35,000 MILE SERVICE CHANGE OIL AND OIL FILTER CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTER WATER LEVES AND CABLE ENDS. CHECK POWER STEERING FLUID AND TOP OFF AS NEED ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~35,000 MILE SERVICE PERFORMED TIRES. FR. 5/32 REAR 6/32 BRAKES FR 7MM REAR 6MM
SERVICE: ACCEL PDL & FLR MODI
DESCRIPTION: ACCEL PDL & FLR MODI ~|~PERFORM 9LG CAMPAIGN ~|~ ~|~PERFORMED 9LG CAMPAIGN
SERVICE: BATTERY/COIL SPK PLUG BATTERY/COIL SPK PLUG
DESCRIPTION: BATTERY/COIL SPK PLUG ~|~UPON INSPECTION, BATTERY FAILED LOAD TEST ~|~BATTERY FAILED LOAD TEST ~|~REPLACED BATTERY
SERVICE: DECLINE RECOMMENDED
DESCRIPTION: DECLINE RECOMMENDED ~|~CUSTOMER DECLINED RECOMMENDED REPAIRS ~|~ ~|~FRONT TIRES SOON, INSIDE EDGE WEAR
SERVICE: LOANER CAR
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~ ~|~ ~|~BALANCED ALL FOUR TIRES
SERVICE: WHEEL ALIGNMENT
DESCRIPTION: WHEEL ALIGNMENT ~|~PERFORM FOUR WHEEL ALIGNMENT ~|~ ~|~PERFORMED FOUR WHEEL ALIGNMENT 30767 MILES
DATE: 07/30/2011
REPAIR# 0244129
SERVICE: 30000 MILE SERVICE NON WARRANTY
DESCRIPTION: 30000 MILE SERVICE NON WARRANTY ~|~PERFORM 30,000 MILE SERVICE. CHANGE OIL & FILTER. LUBE ALL HINGES. INSPECT COOLING SYSTEM. INSPECT EVAPORATIVE EMISSION SYSTEM & FUEL TANK CAP GASKET. CLEAN THROTTLE BODY AND ADD FUEL SYSTEM CLEANER. CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR REPLACE A ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~30,000 MILE SERVICE PERFORMED BRAKES 8MM FRONT 7.5MM REAR, TIRES 7/32 FRONT 8/32 REAR
SERVICE: LOANER CAR
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~REPLACE A/C AIR FILTER. ~|~ ~|~REPLACED A/C FILTER(S) 25786 MILES
DATE: 04/14/2011
REPAIR# 0235371
SERVICE: 25000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 25000 MILE SERVICE NON WARRANTY-NON OEM ~|~PERFORM 25,000 MILE SERVICE CHANGE OIL AND OIL FILTER CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTER WATER LEVES AND CABLE ENDS. CHECK POWER STEERING FLUID AND TOP OFF AS NEED ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~25,000 MILE SERVICE PERFORMED F/BRAKES NEW & R/BRAKES 6MM OK TIRES AT 8/32ND, OK - SET AT 35PSI
SERVICE: OTHERS
DESCRIPTION: OTHERS ~|~TECHNICIAN FOUND FRONT BRAKES WORN TO MINIMUM THICKNESS ~|~ ~|~REPLACED FRONT BRAKE PADS, RESURFACED FRONT BRAKE ROTORS, & SERVICED CALIPERS 20662 MILES
DATE: 01/13/2011
REPAIR# 0227266
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~CUSTOMER STATAE REPLACE ALL FOUR TIRES ~|~ ~|~REPLACED/MOUNT & BALANCED ALL FOUR TIRES
DESCRIPTION: WHEEL ALIGNMENT ~|~PERFORM FOUR WHEEL ALIGNMENT ~|~ ~|~PERFORMED FOUR WHEEL ALIGNMENT 20437 MILES
DATE: 01/10/2011
REPAIR# 0226930
SERVICE: 20000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 20000 MILE SERVICE NON WARRANTY-NON OEM ~|~PERFORM 20,000 MILE SERVICE, CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVEL AND CABLE ENDS. CHECK POWER STEERING FLUID ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~20,000 MILE SERVICE PERFORMED F/BRAKES 6MM & R/BRAKES 7MM, OK TIRES NEED TO BE REPLACED - SET AT 35PSI
SERVICE: LOANER CAR
DESCRIPTION: LOANER CAR ~|~INSTRUCTION/NOTES ARROWHEAD LEXUS HAS PROVIDED A LOANER FOR YOU. WE ONLY ASK A $10.00 PARTICIPATION TO OFFSET FUEL AND MAINTENANCE COSTS. PLEASE RETURN BY 6PM WHEN YOUR VEHICLE IS FINISHED OR A $50.00 RENTAL CHARGE PER DAY WILL BE ADDED TO YOUR INVOICE LO ~|~ ~|~LOANER CAR 19729 MILES
DATE: 12/24/2010
REPAIR# 0225845
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~CUSTOMER STATES THAT THERE IS A SLOW LEAK AT THE LEFT REAR TIRE ~|~ ~|~REPAIRED L/R TIRE 15527 MILES
DATE: 10/11/2010
REPAIR# 0219342
SERVICE: 15000 MILE SERVICE NON WARRANTY
DESCRIPTION: 15000 MILE SERVICE NON WARRANTY ~|~PERFORM 15,000 MILE SERVICE CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. REPLACE AIR FILTER CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVEL AND CABLE ENDS INSPECT EX ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~15,000 MILE SERVICE PERFORMED TIRES FRONT 6/32 REAR 5/32 BRAKES FRONT AND REAR 8MM
SERVICE: LOANER CAR
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~REPLACE A/C AIR FILTER. ~|~ ~|~REPLACED A/C FILTER(S) 10410 MILES
DATE: 06/21/2010
REPAIR# 0210384
SERVICE: 10000 MILE SERVICE NON WARRANTY-NON OEM
DESCRIPTION: 10000 MILE SERVICE NON WARRANTY-NON OEM ~|~PERFORM 10,000 MILE SERVICE CHANGE OIL AND OIL FILTER ROTATE TIRES AND CHECK TIRE PRESSURE AS WELL AS ALIGNMENT WEAR. CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS CHECK POWER STEERING FLUID A ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~10,000 MILE SERVICE PERFORMED TIRES FRONT 6/32 REAR 5/32 BRAKES FRONT 7MM REAR 8MM 5302 MILES
DATE: 03/11/2010
REPAIR# 0201478
SERVICE: 5,000 MILE SERVICE
DESCRIPTION: 5,000 MILE SERVICE ~|~PERFORM 5,000 MILE SERVICE CHANGE OIL AND OIL FILTER AND ROTATE TIRES CHECK TIRE PRESSURE AS WELL AS CONDITION OF TIRE. INSPECT AIR FILTER CHECK ALL FLUID LEVELS AND TOP OFF AS NEEDED. ADVISE ON CONDITION. CHECK BATTERY WATER LEVELS AND CABLE ENDS. INSPEC ~|~SCHEDULED MAINTENANCE DUE TO TIME OR MILEAGE ~|~5000 MILE SERVICE PERFORMED FRT BRAKES 8MM, REAR 10MM. TIRES 8/32 1202 MILES
DATE: 12/31/2009
REPAIR# 0195150
SERVICE: 1,000 MILE SERVICE
DESCRIPTION: 1,000 MILE SERVICE ~|~PERFORM 1000 MILE SERVICE ( ALL MODELS ) CHECK ALL FLUID LEVELS, TOP OFF AS NEEDED. INSPECT FOR ANY OIL LEAK. CHECK NUTS AND BOLTS ON BODY, CHASSIS AND WHEELS. CHECK HEADLIGHT ALIGNMENT AND AIM IF NEEDED. CHECK LIGHTS, ACCESSORIES AND TIRE PRESSURES. CLEA 165 MILES
DATE: 12/10/2009
REPAIR# 0193407
SERVICE: NON-OEM WINDOW TINTING
DESCRIPTION: NON-OEM WINDOW TINTING ~|~INSTALL WINDOW TINT TINT SPLIT ~|~PER CHIT 6 MILES
DATE: 10/20/2009
REPAIR# 0188838
DESCRIPTION: NON WARRANTABLE OPERATION CODE ~|~AUTO GUARD ~|~ ~|~AUTO GUARDNON WARRANTABLE OPERATION CODE ~|~ ~|~ ~|~VEHICLE DETAILNON WARRANTABLE OPERATION CODE ~|~ ~|~ ~|~PERFORM WINDOW ETCH
SERVICE: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES
DESCRIPTION: PRE-DELIVERY SERVICE FOR USA ALL ALTITUDES ~|~PDI ~|~PER FACTORY ~|~PERFORM PRE DELIVERY INSPECTION
DATE: 08/09/2016
REPAIR# 0173452
DATE: 06/15/2015
REPAIR# 0154570
SERVICE: RED TIRE
DATE: 09/24/2012
REPAIR# 0275482
DATE: 05/17/2012
REPAIR# 0266940
SERVICE: LOANER CAR
DATE: 02/09/2012
REPAIR# 0259118
DATE: 02/06/2012
REPAIR# 0258812
DATE: 11/30/2011
REPAIR# 0253805
SERVICE: MISC
DATE: 11/03/2011
REPAIR# 0251586
SERVICE: LOANER CAR
DATE: 07/30/2011
REPAIR# 0244129
SERVICE: LOANER CAR
DATE: 04/14/2011
REPAIR# 0235371
SERVICE: OTHERS
DATE: 01/13/2011
REPAIR# 0227266
DATE: 01/10/2011
REPAIR# 0226930
SERVICE: LOANER CAR
DATE: 12/24/2010
REPAIR# 0225845
DATE: 10/11/2010
REPAIR# 0219342
SERVICE: LOANER CAR
DATE: 06/21/2010
REPAIR# 0210384
DATE: 03/11/2010
REPAIR# 0201478
DATE: 12/31/2009
REPAIR# 0195150
DATE: 12/10/2009
REPAIR# 0193407
DATE: 10/20/2009
REPAIR# 0188838
Except for the big gap in maintenance history, approx 52k to 89k I think it was? Everything in the first 52k looked good, very good as a matter of fact. The big gap doesn't mean anything went wrong. I've actually sought out a mechanic that personally works on my car. Someone can correct me if I'm wrong, but all it does it hurt the resale value. The good news is there's no record of coolant leaks, meaning you might just have a chance for Lexus to lend a hand. I am aware the Lexus owners service history allows the owner to manually input data to update the history. That would have been great if the owner would have followed up on that. Your car looks like it was well taken care of. Like most, we all wise up and find ways to get the maintenance done if not better than the dealership.
