Moonroof not retracting all the way back..
Old 08-30-16, 07:59 AM
joedaddy1
joedaddy1's Avatar
Default Moonroof not retracting all the way back..
Can someone test this out for me on their car?
On my car, when I use the one-touch slide back function, the glass still has about an inch left to go. I can press the open bottom again and it'll go that final inch. Is this normal?
Thanks
Old 08-30-16, 08:02 AM
GregCanada
GregCanada's Avatar
I asked lexus, and they said this was normal. it's annoying, for sure.
Old 08-30-16, 08:05 AM
joedaddy1
joedaddy1's Avatar
thanks for the quick reply..
another pet peeve is that we can't set the moonroof to NOT move when opening the windows using the key fob..
or is it possible?
Old 08-30-16, 08:10 AM
JDR76
JDR76's Avatar
Agree with the others that it is normal. The first position is intended to be as far open as it can go while avoiding too much wind buffeting. You have the option to go all the way back and accept more wind noise should you choose.
Old 08-30-16, 08:57 AM
yardie876
yardie876's Avatar
IIRC, you can set only the windows to open with the fob.
Old 08-30-16, 09:34 AM
joedaddy1
joedaddy1's Avatar
Originally Posted by PatrixUSA
Doesn't appear you can separate on the 14 GS350. Page 798 in online manual.
http://drivers.lexus.com/t3Portal/do...f/OM30D41U.pdf
thanks for the bad news
Old 08-30-16, 09:44 AM
TrevorTran
TrevorTran's Avatar
Yes this feature is normal, but I agree can be a bit annoying when you want the moonroof to retract all the way.
Does anyone know if you can CLOSE all the windows and moonroof with the keyfob, or is pulling the physical key out and turning it in the door handle the only way?
JDR76
JDR76's Avatar
It looks like, with the windows rolling down, you can select to either tilt or slide the moonroof, but not leave it closed.
26. Open Windows with Elec. Key
When pressing the unlock button on the electronic key for 3 seconds:
□ The windows will not roll down. (Standard) = Off
□ All the windows will roll down. = On
27. Open windows warning*
When pressing the unlock button on the electronic key for 3 seconds to roll down
the windows:
□ The buzzer will not sound. = Off
□ The buzzer will sound. (Standard) = On
* Option #26 must be on.
28. Slide/Tilt Moonroof with Elec. Key
When option #26 is on, the moonroof can be programmed for the following:
□ Slide. (Standard)
□ Tilt.
Old 08-30-16, 10:16 AM
TrevorTran
TrevorTran's Avatar
The key fob window / moonroof customization is OPEN only, you'll need to use the mechanical key to CLOSE. See link and page reference in above post (#6). Would have been nice, but I figure it's probably a safety thing - Lexus doesn't want unintended closure of windows while "butt" pressing the lock button on the fob.
Gotcha, thanks for the clarification!
Old 08-31-16, 11:37 AM
madrussian
madrussian's Avatar
My wife's E90 does that same thing. I haven't tested it on the GS, but on the BMW if you leave it in the "semi" opened position and driving down the highway, its quite pleasant. Once you open it all the way and are going 45+ MPH, the air stops gliding over the car and it creates a deafening booming noise.
LeX4u2nV
06-05-20 07:52 AM
jacklex
01-30-17 11:06 PM
ramshyd
07-05-12 12:52 PM
phillies
01-17-09 10:42 AM
ap0718
03-06-01 03:58 PM
Quick Reply: Moonroof not retracting all the way back..
