Gear shifter plate cover loose
Old 08-29-16, 04:19 PM
lexluver
lexluver's Avatar
Default Gear shifter plate cover loose
Anyone know a quick fix to get this gear shift plate cover back into place?
Old 08-29-16, 06:54 PM
greg3852
greg3852's Avatar
I would imagine it would require opening that up to put back in place. It's a simple procedure that should be found in the sticky.
Old 08-29-16, 08:48 PM
comotiger
comotiger's Avatar
Yeah, I agree. You have to pop out the side panels on the central console/transmission tunnel to gain access to the stuff underneath. I haven't removed those panels myself, but I have seen plenty of videos where those things were pried off. They are held to the console by clips at several points. This video might help. Good luck!
Old 08-30-16, 08:43 PM
lexluver
lexluver's Avatar
How to Remove Radio / Navigation / CD Changer from Lexus LS460 2008 for Repair. - YouTube
Thank you for the vid...will give it a try!
Old 08-31-16, 09:50 AM
roadfrog
roadfrog's Avatar
It's easy. I've done it 3 times and never had an issue. Just try not to lose any of the little clips attached to the console.
salimshah
07-29-20 04:40 PM
tjframe
06-18-15 08:53 PM
TheRonTom3
12-19-09 03:56 PM
JimsGX
03-29-09 07:19 PM
Quick Reply: Gear shifter plate cover loose
