Original keyless stops working randomly. Battery is good.
Old 08-28-16, 04:56 AM
yuri.ber
yuri.ber's Avatar
Default Original keyless stops working randomly. Battery is good.
Hello everyone. My 2001 Ultra's keyless remote seems to stop working randomly. I have three original keys, all of them do the same thing. Sometimes keyless works fine but most times it just doesn't do anything. When I press any key on the remote the red indicator on the fob lights up but the car does not respond. All buttons inside the car work just fine, locking/unlocking, physical key unlocks and starts the car ok as well.
Battery in the remotes are fresh, battery is one year old.
Any help is appreciated.
Old 08-28-16, 08:28 AM
JffGRY706
JffGRY706's Avatar
my guess is 2 keys and 1 valet key. valet keys do not work anything but door and ignition. no trunk or glove box .
Old 08-28-16, 09:12 AM
yuri.ber
yuri.ber's Avatar
Three original keys with remotes and a valet key in the plastic mold without any buttons.
Old 08-28-16, 01:13 PM
jayclapp
jayclapp's Avatar
I'd change the batteries again before I'd do anything else. Easy, low cost, and might fix the problem. Worth a try in my opinion.
Old 08-28-16, 04:06 PM
Tom57
Tom57's Avatar
If battery change in key fob doesn't solve it, check the main 12-volt battery connections for any corrosion as well.
Old 08-31-16, 11:26 AM
AlanLS430
AlanLS430's Avatar
I have found my keyless entry has problems in areas with public wi-fi. When I leave that local area, everything works fine again.
Old 09-01-16, 02:54 PM
rkw77080
rkw77080's Avatar
There's a Technical Bulletin about that...
File Type: pdf
bobster99
01-10-18 12:34 PM
babbles
HS 250h Model (2010-2012)
10-31-17 06:05 PM
ChitChat
RX - 3rd Gen (2010-2015)
02-09-15 11:56 AM
dysLEXic
IS - 1st Gen (2001-2005)
01-21-09 09:07 AM
techno
15
03-30-08 09:07 AM
Quick Reply: Original keyless stops working randomly. Battery is good.
