--1997 es300 key fob issue---
Old 08-26-16, 02:41 PM
Alexbenz
Alexbenz's Avatar
Default --1997 es300 key fob issue---
both my key fobs haven't worked in over a year or so an i'm getting to the point i might get rid of the car but for now i still have it and i tried to reprogram the fob again today and i get to the part where the locks cycle once after the reprogram BUT when i press the lock button nothing happens...battery is new and i haven't tried buying a used fob off ebay since i figured what's the chances both stop working. Only issue was my truck lights burned out when i was changing a led bulb in it and it cause some weird electrical issues but when i changed the fuse everything was fine except the fobs acted weird . They'd work on and off until once day they stopped working altogether. Now i did read it might be the "Factory Anti-theft Module" and it's located behind the radio and there cheap on ebay, about $20 , should i gamble and replace that or it's not worth it?
Old 08-26-16, 06:13 PM
speedkar9
speedkar9's Avatar
How about if you replace the LED bulbs in the tail light back to incandescent bulbs and see if your remote fob function turns back to normal?
They are linked, as the remote fob has to blink the lights when you lock and unlock the car. So if LED's show less resistance than incandescent lights, it might affect the locking function.
Do you have a neighbor or friend with a similar vintage Lexus that you can program your keys to and test that your remote is outputting a signal?
Old 08-26-16, 07:54 PM
Alexbenz
Alexbenz's Avatar
i don't have the bulb for it anymore but i did take it out and that didn't make a difference.
Now when my wife got home i used her key fob and reprogrammed it and it worked. it was working and we left for dinner and just got home and it's not working again. Went through the steps to program it again and it worked while i was inside the car i kept pressing the unlock and at one point it didn't unlock and i couldn't unlock it from inside either from the switch. I had to manually press the switch next to the handle...
No i don't know anyone with a similar car. Now i'm thinking it can be the door lock systems possibly but read it's expensive
Old 08-29-16, 02:24 PM
mmatheny
mmatheny's Avatar
FOB Battery??
Old 08-29-16, 06:17 PM
Alexbenz
Alexbenz's Avatar
I was able to reprogram the fob today and it worked for most of the day till now and noow it's not working. has a new battery btw
Old 09-01-16, 09:29 AM
mmatheny
mmatheny's Avatar
Maybe something is running the battery down - stuck button maybe.
Old 09-01-16, 10:04 AM
Alexbenz
Alexbenz's Avatar
it's randon, sometimes when i turn off the car if i press a button it'll work but if i don't then when i close the door and try it it doesn't work. no idea
Old 09-02-16, 07:00 AM
mmatheny
mmatheny's Avatar
Now it sounds like the button pads themselves are dirty. You can buy replacement rubber button pads on eBay.
Old 09-02-16, 02:39 PM
Alexbenz
Alexbenz's Avatar
don't think that's the problem. there not worn out or dirty because i took it apart. If that's the case then why would the other key fob not work?
Like i mentioned it works randomly now and that makes no sense to me
bigboy0723
11-11-15 09:10 AM
Alexbenz
04-30-14 10:52 PM
czar1259
03-06-14 04:18 AM
Gryder
IS F (2008-2014)
15
10-12-12 07:43 PM
Quick Reply: --1997 es300 key fob issue---
