Does anyone knows what caused that on my spark plug?
Jeff I need your help on this!
Unfortunatelly I wasn't lucky enough to change the spark plugs and go.When I did ,the engine still didn't work properly and Unfortunatelly the broken part that missing from the spark plug ruined one of my cylinders.I m very sad because I take good care of my car.I bought the supercharger from a friend and he never had any problem with it.I drove my car hard because I really like the supercharger sound and bov and I wasn't expecting something like this to happen.I have a spare low mile engine in my garage but I m know thinking if I shoul install the LMS kit back on or not!Was it the AEM meth kit that caused this on the spark plug?My friend who had it never had a problem with his spark plugs
I don't use any a/f gauge or anything else.My buddy had a PLX but never saw any strange numbers on so he told me to install it as is and I won't have a problem.The only thing I don't know is if the methanol have to be replaced because my buddy had it for 3 years and I used it too.
Sorry for my English guys what I mean is I don't know how long methanol last.My buddy had it for 3 years sitting in his garage and he gave it to me with everything else.The only thing that I don't have same as he had in his set up is an exchast.I don't like the noise so didn't get his exchast.The car was running great but 2 months ago made a small stall at 5000 rpm.My mechanic told me that it may be the spark plugs but told me to go for my summer vacations and we would change them after I got back.On my second trip the VSC came on but the car were still running great but when I returned it got worse!The engine shaked at low rpm s and when I went over 100 km it was running great again.
I really liked the extra power and all the compliments from everyone about the fantastic sound of the sc.I don't want to install the new engine without it but I m afraid if I have the same issues again!What should I do
It's possible that the spark plug cracked (from being dropped or whatever), but to me it looks most likely that it got really hot and melted, likely from a lean condition.
Without any AFR logs or EGT information, it would be quite difficult to know exactly what caused it to run lean. It sounds like you're using methanol injection to help with with lack of fuel from the stock tuning, perhaps there was an issue with that system?
Jeff
Jeff
Thank you Jeff for the reply.My buddy can't believe this happened to me.He never had any problems with it that's the reason I got the kit from the first place.I know I like how the car drove with the sc but I m not sure I will ever be sure that everything is working great again when I drive it.
bro never ever run F/I without a wideband installed!! EVER!! and don't let anyone tell you otherwise. allows you to see the issue coming before the issue sees you.
However it looks does look like temps got a little hot.
F/I without a tune is a no no... There are some tuning options out now, If I were installing a kit on my new engine, I would reach out to them.
The stock ECU doesn't compensate enough for fuel and spark. Ticking time bomb..
I wasn't the first who did it guys!Heyarms have the LMS kit also and many others have them without (sharing)any problem.The only diference I have with my friends set up is that I don't have an exchast!Do you think it makes so much diference not having exchast on a sc kit?How does my car got lean and my buddy's plx showed 11:1 at full speed.I will defenatelly fix my car but I want your opinion on whether I should install the sc kit or not.
But look at it like this, your stock engine asks for X amount of fuel, the supercharger needs more than X. You're pushing more air into your engine with the same amount of fuel, that causes a lean condition..
