Painting wood console
I have an 07 GS450h. I really wanted the chrome gear indicator that the 08+ has. I was able to get one on ebay for cheap with console, but the wood was the wrong color.
Is it possible to paint the console to match? I have Piano Black. I would think that would be the easiest color to try and make look good.
Any tips / ideas?
Any tips / ideas?
Any tips / ideas?
Any tips / ideas?
Lol maybe you should take it to a piano repairman. They must have experience repairing delicate wood components and reprinting them in high-gloss black
Whatever route you decide to take, I hope it turns out out great!
Nope, it's a thin layer of wood on an aluminum and plastic backing. A member on the 2GS forum sanded one of the wood panels from his door and sure enough, under the lacquer was real wood.
Wait... 2GS forum? That may have been true for a 2GS... 3GS is plastic... all plastic
Well I guess I can't speak on the "piano black" panels. But I am certain that the "rose wood" is actually all plastic as I have personally removed each panel, sanded them all and wrapped them in carbon fiber.
Haha but technically, plastic is made from wood: plastics are petroleum products, and petroleum is made from prehistoric trees that died in swamps and were immediately covered in mud/water so they couldn't decompose; these undecomposed swamp trees were then covered by layers of mud until the pressure turned them into oil over millions of years, until the day the oil was pumped back to the surface and refined, then sent to a petrochemical plant to be turned into a form that polymerizes readily, and then finally cast or injection molded to form a plastic interior piece. So whether the trim is wood veneer of plastic, it all comes from the same source!
Any tips / ideas?
Any tips / ideas?
