Window // Window Motor Help!
Old 07-30-16, 05:50 PM
ExecLS430
ExecLS430's Avatar
Default Window // Window Motor Help!
Hey LS fam!
I'm new to the LS430, but not new to Lexus. Anyway, i picked up a 2004 LS430 with 185,000 miles.
The problem is that my front passenger window is hesitating when going up or down. It gets stuck, but when i wait a few minutes and then click the "auto up" or "auto down" button. It will usually work. So the question is: is the front passenger motor blown or going out? Or could it possibly a faulty window button switch?
For more information: the problem started immediately after i tried to roll the window down, while my girlfriend was trying to roll the window up, at the same time. Would that sudden reversal of the signal blow the motor, or ruin the switch?
Thanks for any help!
Old 07-30-16, 11:04 PM
offbad
offbad's Avatar
try both the master side and affected side switch. if problem persists, i'm thinking you need a new window motor.
i'm not sure about your signal reversal problem, though.
Old 07-31-16, 01:27 AM
Fixman
Fixman's Avatar
I have a similar issue withe my driver side window. Sometimes when I roll it up in auto it stops close to the top then rolled down. Whiting few seconds and manually riling it up it inches it way up. Takes about couple of minutes.
Now if all is ok and I roll all windows up at the same time drivers window is the slowest. So I figured it the motor that is on its last leg.
I also believe the summer heat makes it worse.
As its summer and I hardly roll the window down I will take this in few months.
Old 07-31-16, 01:29 AM
Fixman
Fixman's Avatar
Ohh my LS430 is a 2004 withe 153 K miles.
Old 07-31-16, 10:52 AM
ExecLS430
ExecLS430's Avatar
Forsure!
Thanks for the input guys. I haven't been able to find conclusive results on here..
Therefore, i'll probably end up switching the motor and hope that fixes the problem. I would think that the motor would go before the window switch, as the motor is under much more load/stress than a simple switch would ever be. Also, i'd hate to replace the switches just to find that the motor is still bad.
Old 07-31-16, 11:46 AM
Fixman
Fixman's Avatar
I don't think it's the switch. But I think it is relatively easy to open and clean.
I believe if you can check the resistance of the motor coile you can determine the health of the motor. Another thing may go wrong is the brashes have worn out.
Hop this can help.
Old 07-31-16, 03:41 PM
hyperopt
hyperopt's Avatar
Clean the switch first. It costs next to nothing but labor, then proceed to change the motor if all else failed.
Old 07-31-16, 04:21 PM
Bocatrip
Bocatrip's Avatar
. I agree. You have nothing to lose. Not sure of what is involved in removal of switch but if not difficult substituting one for another is another option.
Old 07-31-16, 07:56 PM
offbad
offbad's Avatar
you should try to reset the auto window function
http://www.wikihow.com/Reset-a-Car's...ng-the-Battery
Old 08-01-16, 08:21 AM
hyperopt
hyperopt's Avatar
Does this procedure apply to the LS430? It sounds generic.
supra9398
05-17-14 05:48 PM
Downfall75
06-07-08 09:28 PM
wynstan
RX - 1st Gen (1999-2003)
10-19-07 11:13 AM
LexusDaisy
Maintenance
04-05-06 09:33 PM
LS_4Will
05-12-04 12:54 AM
Quick Reply: Window // Window Motor Help!
