overheating
Old 07-28-16, 08:18 PM
princess87
princess87's Avatar
Default overheating
hallo guys ,,
ill like to see if any of yall had any problem with an overheating motor, for the records i already took my baby the mechanic, it didn't act up with the mechanic but for some reason every time i try to leave it on for over 15 min (with engine running) starts to over heat on me, i already change the thermostat.... neither that help;..
any suggestions would be thanked ...
Old 07-28-16, 08:40 PM
Zmon
Zmon's Avatar
Is both the radiator and overflow tank filled with coolant (Toyota Pink, Zerex Asian are preferred) to the top? Is the radiator fan turning on at all once it reaches the half way mark on the temp gauge?
Old 07-28-16, 11:37 PM
MWIS350
MWIS350's Avatar
Maybe because of water pump leaking.
Old 07-29-16, 01:59 AM
P128sniper
P128sniper's Avatar
Yea check water pump.
Old 07-29-16, 07:42 AM
princess87
princess87's Avatar
Default Thank you
I just replace the water lump a year ago , also I fill the reservoir with pink (Toyota coolant) and the radiator I'm starting to think is the relax .. Since I guess the fans are not turning ...
Old 07-29-16, 07:43 AM
princess87
princess87's Avatar
Default My baby got 0 leaks
I'm starting to think it may be an electrical problem
Old 07-29-16, 07:46 AM
princess87
princess87's Avatar
Default Thank you for replying
I check both of the fluids last Friday's both tanks are full to the top, as well the themperature gauge gets half way when starts to get hot , but that only takes a few LA lights in order to let that happend :/
Like I say I'm starting to think is the fan relay , I'll check that out today , I hope is not the water pump again
Old 07-29-16, 12:39 PM
Gville350
Gville350's Avatar
Check the radiator cap. Quite a few member have said theirs have fallen apart over time; this could lead to an overheating condition.
Old 07-29-16, 10:07 PM
princess87
princess87's Avatar
Default Thank you
This is the 3rd dam radiator cap I had replace , mainly that was the big issue . I replace the fan relay today in this close to take it to the dealership
Old 07-31-16, 04:46 PM
Gville350
Gville350's Avatar
Third one? Are you replacing with OEM or aftermarket?
lanthern22
GS - 1st Gen (1993-1997)
01-06-10 08:31 AM
dmsrated
Performance
01-02-09 01:11 PM
madmax98
05-13-08 10:18 PM
pitchblaq
07-27-07 02:51 PM
esandes
Maintenance
14
06-26-06 11:12 PM
Quick Reply: overheating
