Stock but error code?
Old 07-27-16, 01:48 PM
jjc250
jjc250's Avatar
Default Stock but error code?
I've done a few frequent highway drives in the past few days and today the Check VSC light came up all of a sudden while I was cruising.. The car has stock intake and I replaced both air filters a year ago. Any ideas?
Old 07-28-16, 09:00 AM
Gville350
Gville350's Avatar
Clean the MAF with MAF-specific cleaner. How many miles on your current set of spark plugs?
Old 07-28-16, 09:39 PM
jjc250
jjc250's Avatar
I will do so. Hopefully it's nothing major. According to LexusDrivers the current set of spark plugs have only ~25k miles on them. I also ran a health check through techstream and it appears the MAF is ~50 gm/sec
Old 07-29-16, 02:47 AM
DickH
DickH's Avatar
The maf reading will vary depending on rpm and throttle position. I've seen my maf reads from 7-216 GM/sec. If your reading too rich the maf is reading high. This could be from turbulence around the maf, try cleaning the maf and inspect the intake for anything that looks out of place.
Old 07-29-16, 12:41 PM
Gville350
Gville350's Avatar
Make sure the "blow-by" tube (the one that leads from the valve cover) is connected to the intake pipe.
Rellgeta
08-23-15 06:49 PM
MongooseGA
Performance & Maintenance
24
11-06-14 03:28 PM
AC1984
31
06-10-14 01:11 PM
breakb
Maintenance
08-11-08 08:09 AM
Dx3
01-26-05 06:52 PM
Quick Reply: Stock but error code?
