Vsc, Vsc off, and abs light on 2000 Gs300
Old 05-23-13, 02:11 PM
franz420
franz420's Avatar
Default Vsc, Vsc off, and abs light on 2000 Gs300
Hello Everyone! I just the joined the forum and I just purchased a 2000 Gs300. I'm very excited about getting this car and it drives like a dream. First off I want to say I've already spent countless hours looking for a solution and didn't find one. I know some of you will say do a "search" and I have. My scenario is a little different though.
1. The lights come on every once every 4-5 times I drive the car. The brakes are not hard or soft. They feel the same whether the light is on or off. No check engine light.
2. I've tried to do the "zero point calibration" but couldn't get it to work. I've seen a few different diagrams of which the ts and cg terminals of the DLC3 are in different places. I'lll try to attach a photo of the pins in my DLC3. I don't even see contacts that would match up on mine! (The terminals I labeled are in my own order for simplification)
3.What else can I look for to try to isolate?
Thanks everyone for the help!!!!
Attached Thumbnails Vsc, Vsc off, and abs light on 2000 Gs300-gs300-obd2.jpg   Vsc, Vsc off, and abs light on 2000 Gs300-gs300-obd2-2.jpg
Les916 (12-30-19)
Old 05-23-13, 05:07 PM
FrankT
FrankT's Avatar
Verify your alternator is charging properly.
jettate (05-24-21)
Old 05-23-13, 05:09 PM
franz420
franz420's Avatar
Battery is 12.6 when the car is off. And 14v when it's running. Thanks
Old 05-23-13, 09:29 PM
YxUxMADDDD
YxUxMADDDD's Avatar
Recent brake job? Suspension swap? Mine came on after that. I did what you did as well and that didn't help.
Old 05-24-13, 07:26 AM
franz420
franz420's Avatar
YxUxMADDDD - I haven't done any suspension or brake work. What did you do to solve the problem, or did you just not worry about it?
Old 05-24-13, 07:31 AM
porn-adkt
porn-adkt's Avatar
I dont know why some of you try to search for the meaning of the universe..
Make it Simple....Take the car to a get the codes read then either calibrated or erase it and go from there..
Old 05-24-13, 09:21 AM
GS4_Fiend
GS4_Fiend's Avatar
You need a scanner that is able to read ABS codes. That's the only way bro.
QLex300 (12-25-21)
Old 05-24-13, 09:47 AM
PushinLEX
PushinLEX's Avatar
This. This exact problem happened to me before my OEM alternator failed.
jettate (05-24-21)
Old 05-24-13, 03:59 PM
franz420
franz420's Avatar
Thanks guys. I'll keep an eye on the voltage output from the alternator and I'll get it scanned next week. I'll let you guys know. Thanks for the replies and advice!!!
Old 05-28-13, 04:03 PM
MonkikiX
MonkikiX's Avatar
Another vote for the alternator. My GS400 did this and the next day the alternator started making a horrible whine. Replaced it and all has been well since.
jettate (05-24-21)
Old 05-29-13, 08:12 AM
KeyKeeper
KeyKeeper's Avatar
Easy way to test this.
Start car
Turn on AC to max
Turn on Ws wipers
Turn on headlamps and put on high beam
Turn on stereo
Let engine get hot enough for cooling fan to hit high.
check voltage. If below 13.3v at battery, suspect alternator is on its way out.
Replace with DENSO alternator, the aftermarket ones are junk. May be better to have yours rebuilt at a shop since the rectifiers and brushes are usually the weak links and easily available for replacement.
May sound strange but has your drivers door window started acting weird at times?
Old 05-29-13, 07:36 PM
Gunnut
Gunnut's Avatar
Same here. Go have the alternator tested.
Old 06-04-13, 06:15 AM
franz420
franz420's Avatar
Wouldn't you know that my alternator took a dump yesterday!!! Exactly what you guys said. Replaced it now the Vsc lights aren't on anymore. Thanks guys
Old 07-31-13, 08:28 AM
Riksgs808
Riksgs808's Avatar
Hey guys, Ive had the gs for about 6 months and has been great, but this morning drove it first thing and half way to my destination i have this same vsc, vsc off lights coming on. But the check engine light is on as well. Do you guys think its still the alternator?? Some input asap would be great as this is my daily driver.
Old 07-31-13, 08:34 AM
porn-adkt
porn-adkt's Avatar
SO once again we start Guessing? Get your codes read and start from there.. But if I do have to guess, im gonna say its your left rear bearing
Quick Reply: Vsc, Vsc off, and abs light on 2000 Gs300
