Spark plug change every 60K or 120K
Old 12-09-11, 02:35 PM
DRivera250
DRivera250's Avatar
Default Spark plug change every 60K or 120K
i usually get my oil changes done at the dealership. don't blast me for not doing my own work on my car. at around 60K i asked my advisor to also change out the spark plugs, but he said not to worry about it till 120K. now my advisor has always been good and has never tried to upsell me any work on my car. I spoke to another service advisor and she recommends that they should of been changed out at 60K.
should i change them out now or at 120K? i'm at 68K btw.
Old 12-09-11, 02:57 PM
brettno1
brettno1's Avatar
According to the manual, they should be changed at 60K
Old 12-09-11, 03:06 PM
calvin2376
calvin2376's Avatar
There's no mystery here, check your manual. Scheduled maintenance guide calls for spark plugs every 60k. Up to you whether you want to abide by Lexus recommendations.
Old 12-09-11, 03:11 PM
jbjones85
jbjones85's Avatar
60k according to the manual.
Old 12-09-11, 03:23 PM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
Most long-life iridium spark plugs get changed at 120,000 miles (192,000km), however the IS plugs are supposed to get changed at 60,000 miles (96,000km). The service advisor might not have been aware the IS gets them changed more often, but they should be changed.
Jeff
Old 12-09-11, 03:54 PM
starknight
starknight's Avatar
Supposedly you change at 60k....but u can still change until they out >.<
Old 12-09-11, 04:34 PM
NafisC
NafisC's Avatar
I've heard aftermarket plugs aren't accepted well by 2GIS motors as some people have had problems as far as engine knock? Can anyone chime in on the matter (not thread jacking of course)?
Old 12-10-11, 03:02 AM
KillaIS250
KillaIS250's Avatar
Since you have to change them every 60k anyways and the OEM spark plugs aren't really that expensive, there's really no point in going aftermarket when it comes to the spark plugs!
Old 12-10-11, 10:02 AM
shui3000
shui3000's Avatar
You only have 3 options for Iridium plugs (that I know of). Autolite, NGK, and the OEM Denso plugs.
Autolite isn't a true iridium plug, so that's out of the question.
NGK, always a great choice, but they are more expensive than the OEM Denso plugs, so you might as well go OEM.
I am curious as to whether or not the spark plug change interval can be every 100k-120k miles. 60k miles just seems so short.
Old 12-10-11, 10:18 AM
NastyIS
NastyIS's Avatar
You spoke with someone that doesn't have a clue when he told you 120k. They are supposed to be replaced @ 60k. I recently replaced mine and I'm glad I did. I can tell a difference.
Old 12-10-11, 11:06 AM
Kurtz
Kurtz's Avatar
CAN it be? Sure. You can also probably go 60k miles between air filter changes/cleanings too instead of 30k.
In either case your car might run like crap and shorten it's life though.
For the typical length of ownership the difference between a 60k and 120k plug change interval is one extra change. Just follow the manual.
Old 12-10-11, 11:18 AM
shui3000
shui3000's Avatar
The plugs are built to last 120k miles, so that's why I'm asking as to whether or not that can be followed with in our cars.
Just like many people go on 10k mile intervals for syn oil changes instead of 5k mile intervals, it's not necessary. So I'm asking as to whether or not it is necessary to change the plugs at 60k miles.
Old 12-10-11, 11:24 AM
Vroomin350
Vroomin350's Avatar
never hurts to follow the manual.
Old 12-10-11, 11:57 AM
Jeff Lange
Keeping it Real
Jeff Lange's Avatar
The plugs are built to last 120k miles.
Says who? Not Denso. They typically refer people to the manufacturer for service life for spark plugs, as different engines can change the life expectancy. Toyota/Lexus is the only manufacturer that uses FK20HBR11 Denso spark plugs, and every engine they use it in has a 60k mile service life.
As far as I know, nobody uses FK20HBR11 plugs with a service interval longer than 60k miles. The FK spark plugs are "High Ignitability Plug" specifications with a 0.55mm electrode. Most Toyota/Lexus models with the 120k mile interval use the much longer life SK plugs with a 0.7mm electrode.
Jeff
Old 12-10-11, 01:15 PM
jbjones85
jbjones85's Avatar
I would use OEM plugs and just change them according to the manual. Its cheap.
Quick Reply: Spark plug change every 60K or 120K
