Max wide REAR wheels for performance tires ...
Old 02-18-11, 09:16 PM
qphoton
qphoton's Avatar
Default Max wide REAR wheels for performance tires ...
I need to install maximum wide REAR wheels without any fender work (may be light shaving, but not more).
I have read all topics here about wheel fitment but did't found answer ...
What maximume wide for REAR wheels is possible?
I want to purchase drag tires - HOOSIER Drag Radial 315/30R18 or 335/30R18 (only this sizes for R18).
At minimum i need to install 10.5J for 315s, but best size is 11J.
For 335s i need 12J rims.
Please help me to make right choice without problems with fitment.
Thanks in advance!
Old 02-18-11, 09:22 PM
GS4_Fiend
GS4_Fiend's Avatar
The was one guy posted up using 285 or 295.
Old 02-18-11, 09:23 PM
SoCal Cyco
SoCal Cyco's Avatar
it all depends on how low you are
Old 02-18-11, 09:26 PM
qphoton
qphoton's Avatar
I've tein flex installed, so it is no problem to set any height. The height is not my goal. (sorry for my english)
Old 02-18-11, 10:19 PM
qphoton
qphoton's Avatar
I think you talk about SoCalSC4's setup?
I was look it but there is no any offset info
I think it is must be about 50-55 offset for 11J .. What you say?
Old 02-19-11, 11:13 AM
qphoton
qphoton's Avatar
OK, another words - What maximum backspace available for REAR wheels?
Old 02-19-11, 11:19 AM
epic1si
epic1si's Avatar
i'm currently running 285/30/19 in the rear.
previously i was running 295/30/19 in the rear.
the only reason i changed was i couldn't find a 295/30/19 in the rear the day i needed them. i will probably go back to the 295/30/19 when i get a chance.
i personally can't see why 315 won't fit as long as you raise it up and set the suspension to stiff so it doesn't squat in the rear.
Old 02-19-11, 11:29 AM
JeffTsai
JeffTsai's Avatar
The 315/325 will fit. You just need a higher offset wheel. A rim with spec of 18x11 +45 should get you close. You might need to go a little higher on the offset(like +50 or +55), but that's a pretty close guess.
I ran 305 in the rear of my car on a +38 wheel.
Old 02-19-11, 12:37 PM
qphoton
qphoton's Avatar
Thank you epic1si and JeffTsay for info,
JeffTsay, could you'll say your rims width that have +38 offset with 305s?
May be you known available backspace for GS2?
I think to buy Tanabe SSR Professor SP-1 rims model S118110 ("SL - 84mm", width 11J) with SBC coating. It has +49 offset. What you'll say?
http://www.ssr-wheels.com/wheels/sp1_17181920.asp
I tried to search any other 18x11J wheels with offset 50-55, but not successful.
I think only custom wheels can have this big offsets.
Old 02-19-11, 12:47 PM
GS4_Fiend
GS4_Fiend's Avatar
Those looks like work miesters. Very nice.
Old 02-19-11, 01:21 PM
Sonic_RC
Sonic_RC's Avatar
If you plan to run 11" or 12" wide in the rear you have to roll or shave your rear fenders. if you are going 11" wide I recommend 30-40 offset with a 315/30R18 tires. if you get 11" wide with a 50-55 offset I will garantee it will touch your rear suspension
Old 02-19-11, 01:33 PM
qphoton
qphoton's Avatar
Then I can buy the 11J rims w/ 49 offset and can use some spacers for most close fitment?
Old 02-19-11, 02:02 PM
Sonic_RC
Sonic_RC's Avatar
If you are using this wheel setup for drag use you do not want to use spacers as it can be very dangerous. if you get a +49 offset and then you find out you need a 10mm spacer then that means you just lost 10mm of thread for the lug nut so you will not have enough turns (unless you buy extended studs). I recommend buying wheels that fit properly without using spacers
I'm currently using a 20x11 +33 on the rear of my vehicle and it is very close to the shock tower and flush with the fender. I'm using a 275/30R20 with rolled fenders but I cannot fit a 315 unless I pull the fenders more. I might get away with running 295/25R20 but that is pushing it. What you are planning to do is run something more extreme then what the car is designed for. So if you want 315/30R18 on a 11j rim you will need to do some fender modifications
Old 02-19-11, 03:02 PM
qphoton
qphoton's Avatar
Hmm, JeffTsay use 305 tires with +38 offset rims ...
.. and as I mean without any fenders mods
Old 02-19-11, 05:50 PM
Sonic_RC
Sonic_RC's Avatar
But he never mentioned if he cut/rolled his fenders. As I mentioned in my previous post if you run 11j you will need a offset between 30-40 so JeffTsai is right in that case. but when he said...
I believe this is wrong information and I am 100% sure this will touch the rear suspension.
I sell wheels and tires for a living so believe me when I say I know what I'm talking about and I eat, breath and sleep about offsets and sizing LOL. If you want a 11" wide rim with the most fender clearance I recommend a +37-40 offset. But you still may need to shave the rear fender because the tire is so wide but I'm not 100% certain, you might get lucky but that is your best shot. I suggest try that first and if the tire still rubs shave the rear, its not a big job or a big deal, just make sure to reseal it to prevent any rusting.
Quick Reply: Max wide REAR wheels for performance tires ...
