Is Supra steering rack shorter ratio? Swappable?
I'm spoiled by my competition package BMW sedan and it's really tight steering. 45 degree turn of the steering wheel will get me around a 90 degree turn.
I'm curious if the Supra rack is shorter and if it's swappable. Sometimes in my SC I feel like I'm driving a schoolbus.
Thanks
Thanks
i have the rack out of my mkiv but im not about to take apart the SC too just to take measurements. id be happy to take some measurements of my supra rack if someone has a SC rack laying around that they can measure, that way we can compare
you could just replace your old worn out steering rack bushings if you haven't already, replace the upper and lower control arms with ones from a supra (the rubber bushings are alot harder than the ones on the SC) and lastly replace the sway bars with ones atleast from a TT supra or get some aftermarket ones. that will help the crappy steering alot, but to top it off get some nice coilovers too if you don't already have some
LEXXIUM (10-30-19)
^^ I already have all of those
It's the lock-to-lock that I think sucks (compartively). I understand that it's a luxury car, thought there is always room for improvement.
I found this!
Steering ratio: 17.5:1 on Supra and Supra Turbo.
Turns, lock to lock: 3 on Supra and Supra Turbo.
from mkiv.com. Still searching from the SC300 ratio, but I suppose I could just go out to the car and measure the lock to lock. It's cold and late though, I'll do it tomorrow.
I found this!
if you want quicker steering get the following:
Stance super angle kit: http://stance-usa.com/sus/products/c...uper-angle-kit
also look into Powered by Max inner tie rod spacers
or get Alex Pfeiffer to mod your stock spindles(not good for road racing. gives you a funny feeling at speed)
I'm not sure that changes how "quick" the steering is... it looks like it just increases how far you can turn the wheel. At least the description says it adds up to 10% more angle.
Yea, you could make sharper turn-arounds, but you increase the lock-to-lock.
The goal would be to REDUCE lock-to-lock so less steering input gives MORE steering angle. What am I missing?
