pcv valve
Old 08-09-09, 08:10 PM
powerslide
powerslide's Avatar
Default pcv valve
Where is the pvc valve located and how do you clean it? If it is dirty, does this accelerate the engine sludge issue? I am about to bring it in and get the timing belt changed. I am thinking about paying Lexus while it is in the shop to drop the pan and check the oil pickup for sludge or pull the valve cover. Or what ever they have to do to check or sludge. I have a 2001 with 86,000 miles.
Old 08-10-09, 12:48 AM
code58
code58's Avatar
Powerslide-The PCV valve is on the passenger side on the rear valve cover. I personally would replace rather than clean, they're cheap. I wouldn't advise buying a Fram though, matter of fact I wouldn't advise buying anything Fram. Just don't trust their stuff. They were a good company at one time, but like all too many, IT'S ALL ABOUT MONEY. It is important that the PCV is clean and works freely. I think it is a good idea to check the oil pick-up screen. It's easy (the #2 pan is easy to remove to check it) and if you saw it and how small the opening is, you'd understand why I say that. Removing the front valve cover is also important to check for sludge, but unless the sludge is really bad and has blocked the return holes, the pick-up screen is even more important in my opinion. I would want to personally be there to see what it looks like though. One of the posters now, involving an ES was told there was no sludge, whereas the pictures he posted prove otherwise, beyond any doubt. Good Luck!
Old 08-10-09, 04:44 AM
bob2200
bob2200's Avatar
The location of the PCV valve didn't change, but it looks different in the 2001-2003 models than it did in the 1999-2000 ones. Let us know how it looks. I checked mine a few years ago and it looked great.
Old 08-10-09, 06:02 AM
Lexmex
Senior Moderator
Lexmex's Avatar
Here's a photo, it's the area code58 mentioned.
And as bob2200 mentioned, it's going to look different, it's actually metal on the 2001-2003 models (see second photo below). It's also going to be set at a 45 degree angle instead of flat as it is here on my 99.
This photo is one I took from rockauto.com where they had the piece available for $4.11 for the 2001, it's listed under the emission subcategory and it's a BECK/ARNLEY Part # 0450345.
However, verify what you see before you order.
Old 03-01-11, 10:09 PM
richonline
richonline's Avatar
Hello, Lexmex,
I am planning to replace the PCV valve for my 01 RX300 which has a engine oil leakage recently. I wonder if the PCV valve you found from autorock.com has a good quality or I should buy it from Lexus dealer. Thanks a lot. I seem the one you found is very cheap. Thanks a lot.
Old 03-02-11, 03:28 AM
carguy07
carguy07's Avatar
Originally Posted by richonline
Hello, Lexmex,
You can get an OE one from a Toyota dealer for $4-$5.
Part # 12204-20040 (for the metal screw in kind which is what yours should have).
Old 03-02-11, 03:53 PM
richonline
richonline's Avatar
Thanks Carguy07. Picked one up at Toyota today, ~$7.
Old 03-04-11, 05:10 PM
richonline
richonline's Avatar
Guys, just want to share with you all, my 01 RX300 has the plastic PCV valve (yes not the metal one), just replaced it last night. During the work, a nightmare happened: the rubber ring under the PCV valve was broken (it became quite stiff) and dropped into the valve cover (through the hole) when I tried to replace it as well. It was so painful to get it out, after two hours I managed to hook it out with the help of a flat screwdriver. So be very careful, it happened before and it happened again.
Old 03-12-11, 10:51 AM
trhs75
trhs75's Avatar
I'm amazed you were able to get it out -- good for you! Pat yourself on the back (and have a beer!) for that one!
Old 03-12-11, 04:47 PM
Lexspeed
Lexspeed's Avatar
Toyota should not use plastic for a component that is subject to that much heat in that location. They are just asking for trouble like you experienced. Metal is much more durable for pcv use.
Old 05-06-11, 11:18 AM
Iluvlexus
Iluvlexus's Avatar
I have a 2001 RX300. I have not checked whether mine is plastic or metal, but if it is plastic can I install the metal one as the replacement?
Old 05-07-11, 04:39 AM
Lexmex
Senior Moderator
Lexmex's Avatar
No, it's a different set up to my knowledge.
Personally, I'd keep the plastic. I bored mine clean open.
Old 05-08-11, 10:44 AM
Iluvlexus
Iluvlexus's Avatar
Lexmex. First off, I want to thank you for all your informative posts. I am in the process of getting my daughter's new 2001 RX300 resuscitated and I have relied on your guidance to get me thru. It is a pretty great car!
As to this thread, you are right in that all RX330s manufactured before 01/2001 used the plastic PCV valve. That is my vehicle. What is involved in changing it out? I purchased the valve and the grommet. Do they just pop out?
Thanks
Scott
Old 05-09-11, 08:07 PM
Lexspeed
Lexspeed's Avatar
Thanks
Scott
It is a pretty simple job. Yes, just pull it out and pinch the clamp to release the PCV. Insert the new one. You might as well replace the grommet since you bought a new, but most of the time those can be reused.
Old 10-06-15, 12:18 AM
ididit
ididit's Avatar
do I need any tool to twist it? or just simply pull it out. Not too much space left there. Do I need to move anything first?
Quick Reply: pcv valve
