Tein front strut tower bar on my 430
Old 11-03-08, 07:10 AM
FinLIFE
FinLIFE's Avatar
Default Tein front strut tower bar on my 430
Here are the pictures for those who wanted to see. Tein stb with my engine cover still on
Old 11-03-08, 10:48 AM
PHML
Master Thread Closer!!
PHML's Avatar
Thanks for the pics. I think alot of members were wondering about the Tein front STB over a GS430 engine w/ cover.
Does it touch/rub the cover at all? Did you have to modify anything?
Old 11-03-08, 10:50 AM
Debonair
iModerate
Debonair's Avatar
Very nice and helpful pictures. That is some tight clearance on the engine cover. Does it contact at all?
Old 11-03-08, 03:55 PM
FinLIFE
FinLIFE's Avatar
It does require the rear tabs to be slightly bent down or away to allow for the clearance. It does clear with no rubbing, but I placed a thin strip of foam in between there in case it did rub that it would not take paint off.
Old 11-03-08, 06:49 PM
Seize
Loves Snickerdoodles!
Seize's Avatar
Sweet! Looks like it fits quite snuggly!
Old 11-03-08, 07:44 PM
CK6Speed
CK6Speed's Avatar
Looks good. That is about how tight my Carson Tuned type one fits. Mine actually clears the drivers side but slightly touches the passenger side. Going to have to lower my engine cover by a few mm to gain full clearance. I'm still debating whether I should get the TEIN front and rear bar as well. I'm happy with mine, but the TEIN one does look nice as well.
PS. One thing, did you have to keep the stock strut mount spacers or did it fit like that with them removed? I had to keep mine on the Carson one.
Old 11-04-08, 12:52 PM
PHML
PHML's Avatar
From the pic...it looks like the spacers are there.
Old 11-04-08, 03:42 PM
FinLIFE
FinLIFE's Avatar
The spacers are on there..I dont know if I would be able to clear the cover without the spacers, they give it just enough height.
Old 11-22-08, 11:26 PM
aristotle
aristotle's Avatar
thank you so much for this post, this is very helpful.
i finally found a strut bar that will clear the gs430 engine cover. i also have the same intake like yours so i know i won't have any issues with fitting as long as i purchase this type of strut bar.
Old 11-23-08, 01:26 AM
kit cat
kit cat's Avatar
damn, that is a tight fit!
Old 11-23-08, 10:47 PM
PHML
PHML's Avatar
I think you will still need more clearance.
When you rev the engine....or even with normal driving conditions...the engine will move....so the Tein stb will still rub on the engine cover....esp. if its already a tight fit when the engine is off.
Old 11-23-08, 11:19 PM
I8ABMR
I8ABMR's Avatar
looks great, but does it actually make a difference on the street. I was under the impression that the kind of chasis flex that the beace will reduce is only under extreme cornering
Old 12-03-08, 10:17 PM
jlee804
jlee804's Avatar
Thats interesting! I bought my Tein Front Bar 15 months ago and mine did not fit with the engine cover on my 01 430. When I called Tein they were no help and basically said to just live it. Hopefully they changed the height of the towers. Nice to know they fixed the problem.
Old 12-04-08, 12:17 AM
PHML
PHML's Avatar
OP had to modify the rear engine cover mounts so the Tein STB could fit....to my knowledge, they (Tein) did NOT fix the problem.
Old 04-09-09, 05:49 AM
kamlung
kamlung's Avatar
just got my tein bar yesterday... what is the spacer you guys are talking about??? does it go between where the stb will mount onto the body of the car on top of the strut?
where can i order it and is it called a strut mount spacer?
Quick Reply: Tein front strut tower bar on my 430
