Club Lexus Vendor Marketplace The place to find group buys and great deals from ClubLexus' supporting vendors.
Complete built longblocks for the GS400/430 and SC430, talior made to order.
Old 09-09-08, 04:05 PM
Chops@MVP
Chops@MVP's Avatar
Default Complete built longblocks for the GS400/430 and SC430, talior made to order.
Hello gents,
MVP Motorsports is proud to make available to the Club Lexus public complete built VVt-I longblocks. MVP Motorsports is offering these longblocks complete with valve/timing covers, oil pump, new belts, slightly more aggressive camshaft profiles, balanced built rotating assembly, crank pulley affixed, and mild headwork.
Components include:
...Ross Pistons/ total seal rings
...H-beam V8 4340 custom rods w/ ARP 2000 rod bolts
...VVt-I Cams, 208 grind
...Valve Springs, standard
...ARP Head/Main Studs
...Cometic MLS Head Gaskets
...Complete, clean core
...Calico bearings
...mild head porting
Pricing includes finished assembly, on the pallet ready to ship from our loading dock.
Below are pics of our work:
We have a number of different compression ratios available.
11:1 for the NA applications
9:1 for supercharged applications/nitrous
8.5:1 for turbo applications
Pricing for these outstanding longblocks is a very reasonable. The breakdown is as follows:
1uzfe 4.0L VVti........... $13,380
3uzfe 4.3L VVti........... $15,100
2uzfe 4.7L VVti........... $14,100 ***BEST BARGAIN***
Regards,
Robert
Chops@MVP is offline
Old 09-09-08, 04:24 PM
c0wboy
Banned
c0wboy's Avatar
Outstanding, we're back on the map serving the Lexus community. If there is any questions on these, please feel free to ask.
Let me just say this, something I found out and some good general purpose information. A 5.5L Toyota V8 w/ high compression and a massive cam made 690HP spinning to 9000rpm. That's information direct from the race shop.
Thanks!
Eric
c0wboy is offline
Old 09-10-08, 07:06 AM
Rock-a-Lex
Rock-a-Lex's Avatar
GREAT JOB guys!!! I have a GS400, if I eventually go this route of buying a new engine will the car perform the same (the same 300hp/315tq @ crank)? Or will it be quicker? Approx. how much will it be to ship to NY (11779)? Thanks again...
Rock-a-Lex is offline
Old 09-10-08, 07:20 AM
vrferrari
vrferrari's Avatar
Good Morning gentlemen,
I think you had answered this question in a prior post before it was deleted, but here goes again:
Given the new UR engines, can a 3UR (5.7) VVT-i I-force from a LX570/Tundra be transplanted into a 2nd gen GS4XX ?
Are the block sizes differnet than the new 4.6 or 5.0 engines that are currently used in the new LS/GS/IS-F cars ?
A TRD supercharged 3UR combo sounds mighty tempting.
Thanks.
vrferrari is offline
Old 09-10-08, 07:21 AM
c0wboy
Banned
c0wboy's Avatar
300/315 hp/tq is a good starting point, but of course as a displacement goes up and the cam profile becaomes more aggressive, the HP goes up as well. You could be looking at 450HP on an aggressive 4.0L, and much much more on high strung 5.5L iron block. Just depends on where you want to be HP wise.
Shipping of course depends on who is used for transport, but for reference we just had a small aluminum V6 motor come in from Rhode Island that was $250 shipping. Figure between that and $350 shipping to NY for a V8.
Thanks!
Eric
c0wboy is offline
Old 09-10-08, 07:28 AM
c0wboy
Banned
c0wboy's Avatar
Thanks.
Right, the new 'ur engine is massive. It will very nearly will hit the shock tower. Plus rising above that, the new 3ur isn't performance oriented in the least due to open decks, tangless bearings, and hydraulic lifters. There is a solution though. If you're looking for 500 Hp/Tq, we can build a 5.5L NA stroker that will drop directly into your second gen GS, and snap rigt into your harness. In the end, the cost will be less than swapping the massive 3urfe, and last ages.
Thanks!
Eric
c0wboy is offline
Old 09-10-08, 07:53 AM
vrferrari
vrferrari's Avatar
Eric,
Thanks for the info. I had a line on a complete 3UR engine from a new Tundra that was wrecked, and with the coming of the TRD supercharger for this engine, I thought it might make for an interesting swap. I thought there might have been a resonable chance it would fit the engine bay given that the 430 and 460 engines fit into the 3rd gen GS cars.
Oh well.
Old 09-10-08, 10:20 AM
c0wboy
Banned
c0wboy's Avatar
Eric,
Oh well.
Remember too that getting the motor is only a small part of the puzzle. Even if the motor did fit, you have to consider the transmission adapter, motor mounts, and electronics swap over. If you went with the TRD supercharger, it would stick out of the hood 6 inches. What if you took the same investment, and went with a high revving high compression 4.3L with an aggressive cam profile that makes similar power to the 5.7L w/ supercharger? The motor would fit directly into your engine bay, hook up to the transmission, and plug into your harness. Something to consider.
Eric
c0wboy is offline
Old 09-10-08, 01:42 PM
c0wboy
Banned
c0wboy's Avatar
Some good pics of the optional billet stroker crank. It's the best of the best material and quality. This crank converts:
4.0L into a 4.7L
4.3L into a 5.0L
4.7L into a 5.5L
c0wboy is offline
Old 09-14-08, 09:53 PM
shrka
shrka's Avatar
all i can say is "wow"
shrka is offline
Old 09-14-08, 09:56 PM
kyang91
kyang91's Avatar
wow.....you guys are crazy......
kyang91 is offline
Old 09-15-08, 06:44 PM
c0wboy
Banned
c0wboy's Avatar
Nah, just far beyond driven.
Eric
c0wboy is offline
Old 09-26-08, 12:42 PM
c0wboy
Banned
c0wboy's Avatar
Some good shots of a 4.9L NA that we're building for a UK member. Wrapping up and looking great! The PS and AC should be in today, so we'll be looking to get them on tomorrow. The intake has been fitted, so we're going to media blast it for a natural finish and it's good to go. I'll fit the fuel injectors and rails I have here for it on Monday. We should be redy to ship by mid week if all goes well.
Pics of Ed's NA motor next to Larry's 5.4L stroker.
Thanks!!
Eric
c0wboy is offline
Old 09-26-08, 12:43 PM
c0wboy
Banned
c0wboy's Avatar
The rest of the pics:
Thanks!
Eric
c0wboy is offline
Old 09-30-08, 10:34 PM
Tank
Tank's Avatar
wow I wanna cry, I finally found somewhere to send my engine for a rebuild..
Tank is offline
Quick Reply: Complete built longblocks for the GS400/430 and SC430, talior made to order.
