Custom Switch for my NavTool
Time to post my first REAL mod. Quite a few people have installed the NavTool device for video input to the factory navigation screen. PearlPower's post was invaluable in helping me get it installed (it's so good, the NavTool instruction sheet now includes pictures courtesy of PearlPower!)
One thing I will add is that it's an unbelievable PITA to get the connectors that are behind the navigation system in the trunk!
So, I had everything all planned out ahead of time, due to these great instructions. One thing that he didn't cover, however, is where he mounted the switch that comes with the unit.
If you haven't seen it, it's a tiny, crappy, el-cheap-o toggle switch. I took the unit out of the box, took one look at that switch and said "There is no way I'm drilling a hole in my car and installing that hunk-o-crap. There's got to be a better way."
Here's the switch the kit came with...
Well, I don't know if what I came up with is "better" way but, I think it's a much cleaner way...and it's pretty darn cool if I do say so myself.
I wanted the system to have as factory a look as possible. I know that some folks put the switch inside the center console but, this isn't exactly convenient. I wanted the switch to be easily accessible but, invisible.
Here's an observation I noticed. Once the Navigation system screen is open, the "Open" button doesn't do anything. So, I used it.
Here's a short video showing how my video switch works. It's so clean this way!
By the way, this was REALLY tough to figure out!! While I consider myself a very competent electronics technician, I'm not an electrical engineer.
I had to isolate the switch from the existing circuitry in the climate control module. I then ran wires to a DPDT relay. One side of the relay went back into the module to continue doing the existing switch function (opening the Nav door when it's closed). The other side of the relay would control the NavTool. Problem: this is a momentary closure. If I just ran this side of the relay to the NavTool, I'd have to hold the "Open" button down the whole time I wanted to watch the secondary video input. Yeah, that wouldn't work. So, I found a company that makes a momentary-to-alternate-action circuit board. You press the open button once, the relay clicks over and STAYS. Click it again, it releases.
As a side trick, I grabbed ground for my relay-feeding-a-relay circuit from the valet switch in the glove box. So, when the valet switch is out, the top doesn't work, the trunk doesn't open, AND my nav screen door stays closed and won't switch to the other video input. Keeps people out of it!
Again, this is my first real mod so, I request that you be somewhat kind to me. I don't think this is the simplest solution for a switch. There may even be other ways to tap into the "Open" switch besides what I did. All I can say is, this works. And it works beautifully!
If anyone wants exact details, I've got circuit diagrams, parts lists, and parts sources.
If you're considering trying this, in case you haven't figured it out yet, let me be clear... THIS WILL VOID YOUR WARRANTY ON THE CLIMATE CONTROL MODULE...WHICH IS A VERY EXPENSIVE PART!!!!!
-Greg
Last edited by Habious; May 29, 2013 at 01:26 PM. Reason: Fixed formatting for YouTube embedded link
As I am a ham radio guy, I can handle the wiring but I'm not eager to pull apart the dash and fiddle around with the open close switch and the climate control wiring on the SC430 that I have not even purchased yet. Oh, and I think you said the cabling to the Nav unit was really tough or did you say PITA?
But anyway, this mod really updates the Nav functionality in the older SC430's and I don't think the new ones in the U.S. can play DVD's either.
A really great electrical mod!!
[LINK REMOVED]
Here's a picture of the screen with the backup camera in action (looks a lot better in person BTW)
And, without moving the car, here's what that position looks like from outside the car.
I park in a parking garage both at work and at home. The work garage is VERY tight...lots of columns and lots of other cars in close proximity. Having this is REALLY nice! At first I thought it might just be a gee-whiz kind of thing but, it's really nice to have it!
I finally have my Carputer installed and running (that was the ultimate plan for the second video input). Will be posting pics and vid of the installation soon. Was shooting the video tonight when the camera battery died!
On a side note JohnnyCake, if you'd like to see the back-up camera in action, I'd be happy to swing by your place sometime and let you see it in person. I've got a friend I visit regularly in MD so, your place is (kind of) along the way (that offer also goes out to anyone else in the NoVa/DC/MD area). Love showing my work off!
-Greg
I finally have some time to put down some documentation.
Here's a circuit diagram of how it's put together.
First thing I had to do was isolate the switch from the factory circuit. I had to break the circuit board runs and then run a small jumper (since one of the connections runs THROUGH one side of the switch). You can see my jumper wire at the top of this picture.
Once I had the switch isolated, I could tap into the factory switch...like this...
I then spliced into the factory wires so that the one side of the DPDT relay could operate the original function of the switch (open the NAV door).
With all of that done, the inside of the AC control module looks like this...
Rather than getting one larger project box for everything, I decided that it would be easier to tuck the modules away inside the dash with two smaller project boxes.
The MCMConnect relay board is in one box...
And my DPDT relay is in another...
The whole thing, assembed, looks like this...
That's exactly the look I was going for. I don't want the car sitting in a parking lot, have someone walk past, and go "Wow, look at all the crazy modifications he's done to this!"
Most folks don't even see the touchpad until I point it out to them.
I have to say, I LOVE having the Sirius up on the Nav screen instead of buried in the ashtray. And, having every mp3 I own accessible at the touch of a finger; just awesome!
