Door Won't Open From Outside? DO NOT ROLL DOWN WINDOW!
Old 06-09-07, 03:39 PM
Luxor
Luxor's Avatar
Default Door Won't Open From Outside? DO NOT ROLL DOWN WINDOW!
Learned my lesson last night. My drivers door would not open from the outside anymore. Figured that the yellow clip broke off which it did. Didnt think it was that big of a problem since it's a $5 easy fix.
Went to roll down my window and my window stopped 3/4 of the way down. Realized that the rod that connects to the door handle got in the way of the window.
The rod ended up bending downward 180 degrees because of the window. This morning I took off my door panel and found the rod and bent it upwards to normal position, this resulted in breaking the rod off!(almost) This is common on most metals..once you bend it so much it just breaks.
The rod(if it breaks off) is connected to an assembly that will cost you about $260 at the dealer.
This is just a heads up for you guys since this is a common problem on SCs.
Here is a picture of the rod bent downwards:
Attached Thumbnails Door Won't Open From Outside? DO NOT ROLL DOWN WINDOW!-bent-down.jpg
Old 06-09-07, 03:40 PM
Luxor
Luxor's Avatar
Here is a picture after you bend it back up, this is the piece that breaks off:
Attached Thumbnails Door Won't Open From Outside? DO NOT ROLL DOWN WINDOW!-broken-rod.jpg
Old 06-09-07, 03:41 PM
Luxor
Luxor's Avatar
This is how the rod is supposed to look like normal:
Attached Thumbnails Door Won't Open From Outside? DO NOT ROLL DOWN WINDOW!-normal.jpg
Old 06-09-07, 04:12 PM
chanh55
chanh55's Avatar
Mine was broken when I got it. I just got a new one from Aliga.
Old 06-09-07, 11:55 PM
blisiono
blisiono's Avatar
my door stopped working too but i snapped the rod after changing the clip because i rolled down the window. i welded it together though and now it works like new
Old 06-10-07, 02:00 PM
over40driv
over40driv's Avatar
Thanks for the heads up, its always nice to benefit from another guys expearience.
Old 06-13-07, 04:25 PM
Luxor
Luxor's Avatar
Well I went out to the dealer and bought a whole new door latch assembly, and let me tell you.... This thing was a pain in the butt to install! It was almost impossible to take out the old one and install the new one with the window track in the way! It took total of 2 hours do this job.
Here is a picture of what you need to buy if you break off the rod.
Part# 69040-24080($272.80)
The Yellow clip part number is 69293-12040($2.11)
Attached Thumbnails Door Won't Open From Outside? DO NOT ROLL DOWN WINDOW!-door-latch.jpg
Old 06-13-07, 04:47 PM
mikeloc24
mikeloc24's Avatar
Search under "door clip" and you'll see many other threads on this same topic. It has been discussed in depth several times already.
Such as here: https://www.clublexus.com/forums/sho...ight=door+clip
Old 06-13-07, 05:01 PM
Luxor
Luxor's Avatar
I dont understand what you are trying to tell me, I was not asking any questions.
Old 06-13-07, 09:11 PM
stonewis
stonewis's Avatar
One week too late! Happened exactly a week ago.... rolled the window down and snap! Oh, well, live and learn... Thanks to Gazi, I've got a new one on the way... but, I don't look forward to the two hour replacement job!!!
Old 06-14-07, 10:04 AM
chanh55
chanh55's Avatar
Why did you buy it from the stealership. You could've bought it from Aliga and probably would've saved at least 200 bucks...
Old 06-14-07, 02:17 PM
ki_soarer
ki_soarer's Avatar
my clip is fine, but the bottom of that rod is broken on mine. i had it set right so i could open the door, but since ive had it back from the bodyshop, i cant get it to sit in the sweet spot agian. i just dont feel like dealing with it right now... who knows, maybe ill try again tonight.
Old 06-14-07, 02:41 PM
aliga
Former Sponsor
aliga's Avatar
i have 6 actuators available.
75 shipped per side.
Old 06-14-07, 02:51 PM
shlounek
shlounek's Avatar
you guys are lucky at least you could open the door from the inside.
I reember when Mine broke and the car wouldnt be able to open from the inside or outside, it was messed up.
Old 06-14-07, 06:09 PM
JspecSC3
JspecSC3's Avatar
Yeah those door lock actuators can be a pain. I had to replace the one on my little brother's SC. It took me about 20 mins.
Quick Reply: Door Won't Open From Outside? DO NOT ROLL DOWN WINDOW!
