headlight restoration with 1500, 2000, PLastX
Old 07-25-08, 01:08 AM
  #106
MythBuster
MythBuster's Avatar
Cousin Jew
We here have sand storms, and my Nissan patrol headlights became sand blasted.
That is why I want to see if this procedure will apply or not.
I doubt that it is applicable to glass.
My nissan head lights seem and feel like glass, but I need to do some testing first, may be they are some kind of very hard plastic.
Thanks
Old 07-31-08, 12:20 PM
  #107
cbrasian
cbrasian's Avatar
i did mine using rubbing compound then polish i'll send up pics on a thread after i'm done
Old 08-05-08, 09:29 PM
  #108
SClean4
SClean4's Avatar
Nice result I am taking my headlights apart from my SC 400 and wanted to check some different methods out.
Old 08-05-08, 10:08 PM
  #109
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
Originally Posted by MythBuster
Cousin Jew
Thanks
Best way to tell bro is flicking it. Glass makes a DISTINCT sound that plastic as far as i know, cannot emulate. You will be able to tell if its glass or plastic right away. Something about the resonance of glass will give it a light "ding" sound when you flick it. Let us know .
Old 08-08-08, 10:41 AM
  #110
MythBuster
MythBuster's Avatar
Jewcano
They are definitely glass the way they sound when hit with my metal key chain.
You are correct. Glass will respond with narrower bandwidth (Hi pitch) than plastic when exited (Shocked).
Thanks buddy
Old 08-08-08, 11:03 AM
  #111
Jewcano
Jewcano's Avatar
No problem buddy.
As for how to clear them up, I'm kinda stumped, unless you use some high powered polisher
Old 09-05-08, 12:04 PM
  #112
gransinger
gransinger's Avatar
Default PlastX
Please help, I used 1500 and 2000 grit paper. After using Plastx, I still have a haze. If doing this step by hand, how hard and how long should I do each headlight. Also, should I apply it in one direction?Thank you !
Old 09-05-08, 12:12 PM
  #113
Debonair
iModerate
Debonair's Avatar
Is it the same haze you had before you started or is it a new haze from the wetsanding?
Old 09-06-08, 01:37 PM
  #114
gransinger
gransinger's Avatar
Default Haze
It's a new haze.
Old 09-09-08, 02:59 PM
  #115
Jewcano
Jewcano's Avatar
It's a new haze.
Pics definately help us help you. Get some pictures of the "haze" online and we can try to point you in the right direction.
Old 10-10-08, 07:29 AM
  #116
Rich27
Rich27's Avatar
Thanks to everyone in this tread. I was able to make my headlights look a lot better then before, however I still a little haze. I went from 1500, 2000, then Meguiar's plastic cleaner, then polish.
However, on the headlights, I can still see very light scratches from the sandpaper, which I think is causing the haze.
What should I do?
Do I need to use 2500 grit sandpaper, or sand it longer with 2000?
Thanks for the help!!
Old 12-22-08, 02:12 PM
  #117
JoelGs
JoelGs's Avatar
That look great...this is remind me to do that on mine...thanks for the post
Old 01-29-09, 07:55 PM
  #118
Vincent123
Vincent123's Avatar
recently did this to my car. you definitely have to use alot of elbow grease to get the headlights shining again, but it was well worth it
Old 01-30-09, 05:55 AM
  #119
jfelbab
jfelbab's Avatar
PlastX works but it does require a technique and perseverance. The product cuts well initially then kind of dissolves. You need to start with a more aggressive applicator like a MF covered pad and wipe it clean after a couple passes. Otherwise it will contain too much polishing oils and will not be abrasive enough to remove the deeper scratches. Once you are getting close to perfection switch to foam applicators and use less pressure.
FWIW, if you have a rotary or DA polisher this works even better. Meguiar's now has a new product kit designed just for headlight restoration that contains PlastX and a smaller pad and arbor for use in a hand drill for around $25.
Old 02-01-09, 09:46 AM
  #120
Big Mack
Big Mack's Avatar
Thumbs up
If you guys love the Plastx, you really need to try the Mirror Glaze stuff from Meguiar's. Use #17, then #10. In between cleanings, you can use #18 to protect them. I believe, but I'm not 100%, that the #10 has UV protectant in it. Once you've wet sanded with at least 2000, you should be able to hit it with these and make them purdy.
http://www.meguiarsdirect.com/detail/MEG+M1008
I have no pics of the lenses that I've cleaned with this stuff right now, but I've got a few projects to do that will certainly be getting the treatment. Oh, for those with a PC buffer, get a 3.5" backing plate and a 4" buffer pad. Life is good with that.
For you drill users, I do recommend getting a buffer, but you can get a 3.5" backing plate as well and then you can use a 4" pad.
I believe that Chris from Glimmer gives CL members a discount, but you'd want to verify that with him.
Big Mack
Quick Reply: headlight restoration with 1500, 2000, PLastX
